re-doing a/c lines for more clearance.....
Old May 5, 2002 | 11:06 PM
integra7's Avatar
New User
Default re-doing a/c lines for more clearance.....
I am trying to redo my a/c lines for more clearance. Does anyone know where i can get aluminum pipes which I can use to customize the a/c lines? If you do, please let me know...
I also DO NOT want to remove the a/c system, soo dont tell me to remove a/c
[Modified by integra7, 3:07 AM 5/6/2002]
Old May 6, 2002 | 12:01 AM
ILOVEGIRLS's Avatar
Default Re: re-doing a/c lines for more clearance..... (integra7)
i wanna know too.
Old May 6, 2002 | 12:34 AM
turbopimp's Avatar
Modifying the AC lines shouldn't be necessary in order to turbocharge a teg... the lines in front of the radiator can be bent pretty easily by hand to make room for an IC, and the ones in the engine compartment shouldn't be an issue if you remove the top bracket and pull the black flexible line foward. What exactly are you trying to do?
Old May 6, 2002 | 06:55 AM
CovertFI's Avatar
Default Re: re-doing a/c lines for more clearance..... (turbopimp)
i have been waiting for someone to ask this. i would like to know also. some of the lines bend easy and fix the problem but i have 2 that cannot be bent anymore. that need to be redone.
Old May 6, 2002 | 10:53 AM
integra7's Avatar
New User
Of course you can bend the lines and make alittle more room for everything to fit. But I hate having ghetto bent lines all over the place. I want to redo my a/c system soo it looks good. I am thinking about taking the line that runs up the radiator and changing it so it runs along the bottom of the radiator. I just need to know where I can get aluminum a/c lines so I can do a custom a/c setup...
Speedra500
Jul 8, 2007 02:46 PM
battlecrxT
Welding / Fabrication
Oct 11, 2006 05:47 PM
ZhaGg
14
Sep 28, 2004 08:39 PM
