Hey, autometer boost gauge. Can someone give me a rundown on the install?
Just like the basics, like.. where the vacuum lines tee off n stuff.. the shop is installing my turbo, and i was gonna do the boost gauge and turbo timer myself..
Re: Hey, autometer boost gauge. Can someone give me a rundown on the install? (b18tdelsol)
hook up the white wire to a light source, the black to a negative. be sure you use a silicon hose instead of that crappy plastic line they give you. tee it off the intake manifold usually the fuel pressure regulator
Re: Hey, autometer boost gauge. Can someone give me a rundown on the install? (boostedhb)
so at the fpr, thats where it measures how many pounds of boost?
more like the intake manifold. you can usually use any vacuum line coming from the intake manifold. the one on the fpr is easiest to get to. note: dont tap into some vacuum source that has not accounted for pressure drop, ie before the intercooler.
Re: Hey, autometer boost gauge. Can someone give me a rundown on the install? (sushibug)
theres like a little nipple outting on the back of my skunk2 manifold, that wasnt there on my oem on.. can i use that? its the same size as the one the fpr uses. you know, the hose on top of that fpr that goes to the manifold? yeah...
