anyone with a ls engine pumping 400+ hp...with no headwork?
Old May 7, 2002 | 10:57 PM
Lei Siew Long's Avatar
Default anyone with a ls engine pumping 400+ hp...with no headwork?
i was told that w/o headwork (port and polish not upgraded valvetrain), a ls head can't flow well enough to produce that kind of power. is there any truth to this?
[Modified by boostedeg6, 1:14 AM 5/9/2002]
Old May 8, 2002 | 11:54 PM
Default Re: anyone with a ls engine pumping 400+ hp...with no headwork? (boostedeg6)
ttt
Old May 9, 2002 | 12:23 AM
bigTom's Avatar
i will find out tommorro... im going to see an ls dynoed without any porting or polishing... should make over 400 imo
Old May 9, 2002 | 01:37 AM
xrtdac
Guest
Posts: n/a
Default Re: anyone with a ls engine pumping 400+ hp...with no headwork? (ek9t)
If I were to not port and polish my head, Sleeve my block, change the pistons and rods, different cams, more boost, I would hit over 400 no problem. These are my plans for next season. I already have a Benson Built LS block ready with the Iron Sleeves, balanced everything, pistons, rods etc etc. I just need to come up with the 4gs to pay for it. God damn funds.
Currently runing a B18B1 Turbo with 231WHP and 204Ft/lbs. (no built internals) 9psi.
[Modified by xrtdac, 2:40 AM 5/9/2002]
Old May 9, 2002 | 01:41 AM
oooh, i would like to see the results of this dyno run.
Old May 9, 2002 | 03:17 AM
Erik_Pb_Foot's Avatar
New User
it would definatly be much easier with the P&P since the air could flow so much better, but it's not required. I'd definatly highly recommend it though.
-Erik
Old May 9, 2002 | 02:33 PM
xrtdac
Guest
Posts: n/a
Default Re: anyone with a ls engine pumping 400+ hp...with no headwork? (Pb_Foot)
Yeah I still plan on doing that too. That Benson built block is bored out to 83mm and is full P&P.
Old May 9, 2002 | 04:50 PM
dustin's Avatar
Default Re: anyone with a ls engine pumping 400+ hp...with no headwork? (xrtdac)
port & polished blocks
Old May 9, 2002 | 04:54 PM
DLB1994's Avatar
Default Re: anyone with a ls engine pumping 400+ hp...with no headwork? (dustin)
lol
theme
Feb 21, 2009 10:38 PM
93FastLs
Jun 30, 2005 01:57 PM
racer034life
May 14, 2005 09:38 AM
tfalconier
Aug 18, 2004 07:56 PM
