Turbo Preparations
Old May 6, 2002 | 02:46 PM
senpai's Avatar
Default Turbo Preparations
I have the following:
Apex'i SOHC VTEC kit
Blitz BOV
Apex'i VAFC
Walbro 255intank
DSM 450cc injectors
I was wondering if I could install the fuel pump AND the injectors before I do the turbo kit. I want to do this so that I would know what is wrong with what unlike if I installed EVERYTHING at once.
Would I run like **** on a rather stock D16Y8? or can I trim off some fuel with my VAFC?
Thanks!
Old May 6, 2002 | 02:49 PM
sushibug's Avatar
Default Re: Turbo Preparations (maztur)
use the vafc to trim the fuel.
Old May 6, 2002 | 02:52 PM
senpai's Avatar
Default Re: Turbo Preparations (sushibug)
Like what? -35-40%?
Old May 6, 2002 | 02:53 PM
sushibug's Avatar
v-afc
1-4k= -40%
4.5k= -38%
5k= -36%
5.5-7k= -35%
those are some numbers that people use for the vafc hack w/ a turbo installed. i dont know too much about it because i dont own a vafc myself yet.
Old May 6, 2002 | 06:32 PM
ImportHatch's Avatar
So technically with my new turbo motor goin in I could install vafc, fuel pump, and injectors before I put my turbo on If i dropped the fuel with the vafc.....I was just thinkin this today because if you install all of that stuff at once and you got a problem thats a lot of stuff it could be.
Yager-
Old May 6, 2002 | 08:54 PM
Ri5e's Avatar
Default Re: Turbo Preparations (ImportHatch)
install the injectors first and vafc. then lean out the mixture so you can hold a steady idle and drive around etc.... then install the fuel pump, then drive it around
and make sure everything runs good.
then drop the turbo in.
because if u put it on all at once and the car runs funny, u have to find out what the problem is...
gunner6696
Dec 17, 2005 10:19 AM
-[95cxhatch]-
Feb 9, 2004 09:22 PM
jazz215
Jan 6, 2004 01:28 PM
jazz215
Jan 6, 2004 09:53 AM
vet_girl
Aug 23, 2003 07:24 PM
