The last step on my install... need fast help with one more thing! =/
My turbo does not have the standard oil inlet nosil, it has two copper nosils and two flanges. I know they are all 4 for the oil/water... but not sure which two are oil and which two are water. Do you think anything bad would happen if I hooked up the oil lines to the copper outlets and it was in fact the water line? Thanks in advance.
Re: The last step on my install... need fast help with one more thing! =/ (C5_ALLMOTOR)
the oil return is the biggest fitting there...the big fat one...the oil feed inlet is right accross from that...
the water in and out are the other 2 holes
you need teh oil, bt you can skip the water if you wanted too...
[Modified by Slow_ass_4dr, 9:12 PM 5/9/2002]
Re: The last step on my install... need fast help with one more thing! =/ (Slow_ass_4dr)
Does all turbos come with oil and water cooling too? I thought water cooling was only for older turbos...the newer ones didn't have them....
1 Post
Re: The last step on my install... need fast help with one more thing! =/ (xero-cool)
oil inlet is should be facing upward, the smallest hole. The big hole directly below the inet is the outlet, which of course faces down. No not all turbos come water cooled.
Hehe, you remind me of my first turbo install. I posted soo many topics asking for help
Re: The last step on my install... need fast help with one more thing! =/ (intekragsr)
no, you don;t have to run the water cooled for now, but it'll help, so mind as well utilize it later on..
if you're still working on it, IM me, i can answer your Q's over telephone....
stan
