Internal Wastegate Problem
Old May 6, 2002 | 04:24 PM
GorData's Avatar
Default Internal Wastegate Problem
I am having big problems with My greddy turbo kit, I was running 9 PSI with out a problem, I has a Vaccum T that brought up the boost from 5.5 psi, It was running like that for a few month. Now Boost goes past 9 psi and past 11 and 12 and I just let go of the Throttle. So I did what I had to do and Took out the T and changed the rubber hoes from Wastegate to Turbo, to see if it went back to 5.5 PSI and it didnt and just kept on rising. I checked out all the vacuum lines and there was no Leak. What could be wrong, I called my local shop and they said that I had a Wastegate that wasnt closing. How could I go about Fixing this.
Old May 6, 2002 | 04:37 PM
sushibug's Avatar
Default Re: Internal Wastegate Problem (vteccivicsi92)
whoops just re-read your topic... nm
[Modified by sushibug, 1:38 AM 5/7/2002]
Old May 6, 2002 | 04:47 PM
rallycivic's Avatar
if your local shop told you the wastegate was not closing then i think i found your problem...first you need to go out and purchase a new local shop.
after that, and after you inform the shop that a wastegate is always closed and then opens via pressure from the intake manifold.
your internal wastegate may be shot. if its for a mitsu turbo you can find a new one for very very cheap on dsmtrader.com if its garret im not sure where you can get one. they're cheap enough to just try and replace.
~Steve
Old May 6, 2002 | 04:48 PM
sushibug's Avatar
Default Re: Internal Wastegate Problem (rallycivic)
since he said 5.5psi, im guessing its a greddy turbo.. which means.. mitsu turbo.
2kTeg
Jun 12, 2005 10:34 PM
aracer69
Jul 7, 2003 07:47 PM
turbo se
Jun 13, 2003 11:33 AM
yorktonite
Aug 20, 2002 04:37 AM
GorData
May 14, 2002 07:19 PM
