Flex pipe
Old May 7, 2002 | 09:51 PM
a z n t a k's Avatar
Default Flex pipe
I just got me drag 3 turbo kit installed on my gsr last week and noticed that the downpipe does not line up. Any of you guys had this problem?
My question is, should I get a flexpipe made at the local exhaust shop?
Thanks,
azntak
Old May 7, 2002 | 11:09 PM
intekragsr's Avatar
Default Re: Flex pipe (aZn TaK)
i had that problem 2 times in a row with both my downpipes. I put everything on, had it all ready to go, went to the muffler shop, they heated the pipe up and bent it downwards and welded the flange on. I had them cut the flange off the stock header and put it on the dp, and connect straight to the cat.
[Modified by intekragsr, 8:11 AM 5/8/2002]
Old May 7, 2002 | 11:18 PM
93LSivic's Avatar
Did you try loosening the bolts from the turbo to the manifold? I had the same trouble and when I did that I was able to move/twist the turbo a little bit. After doing this the dp lined up better with the rest of the exhaust.
Old May 7, 2002 | 11:47 PM
Spankee2K's Avatar
Default Re: Flex pipe (93LSivic)
All Drag Kits I have seen come with a crooked DP. It seems to go the the left of the car all the time. Just get a flex....you will need it anyway.
WiseGuysCC
May 3, 2006 05:09 AM
egVTI
Jan 19, 2006 09:16 AM
b18cTurbo
Dec 11, 2001 04:41 AM
shamoo
Oct 30, 2001 09:16 AM
