Help with fuel or ignition problem
Old May 6, 2002 | 11:09 PM
Dutchie's Avatar
Default Help with fuel or ignition problem
In the past week when I go above half throttle my car hesitates and misses. It seems worse the more it is warmed up. I've changed plugs and wires which helped for a couple pulls but that's it. Also, a couple months ago my car started taking a long time to start, worse when it is warmer outside. Since then I put in MSD ign+coil and changed fuel filter, but it didn't help. My setup is GSR on 5 psi, walbro 255, RC 440's with techtom chip.
Old May 7, 2002 | 01:32 AM
nosintegra92's Avatar
Default Re: Help with fuel or ignition problem (Dutchie)
Could be running to rich. What are you using to lean out the 440 injectors? Also is your chip setup for turbo if not put the stock chip back in. Most chips for N/A are made to have advanced timing and dump more fuel.
Old May 7, 2002 | 08:55 AM
Dutchie's Avatar
Default Re: Help with fuel or ignition problem (nosintegra92)
The chip is programmed with a wideband O2 on a dyno. I shouldn't be too rich all of a sudden in less something went wrong. I have been running this set-up for 2 years without a problem. My plugs do look rich though, maybe my fpr isn't working properly?
Old May 7, 2002 | 10:11 AM
c_penson's Avatar
did you check the compresion on you engine??
when you open the switch do you hear the fuel pump running?
Old May 7, 2002 | 10:12 AM
c_penson's Avatar
Default Re: Help with fuel or ignition problem (c_penson)
sometimes when the main relay on you car if faulty it takes a while to start the fuel pump so the car sometimes takes a lot to start
Old May 7, 2002 | 10:58 AM
93LSivic's Avatar
Sounds like a problem I had when my O2 sensor was going bad--it didnt throw a code either. Might want to look into that.
Old May 7, 2002 | 11:50 PM
Dutchie's Avatar
I hear the pump come on right away so I don't think it is the relay. It could be the O2 I will try a different one and see if that helps. Anyone else hear using the Techtom chip? I'm not sure if it uses the O2 sensor or not.
Thanx for ideas so far.
AW
Jun 3, 2006 10:40 AM
CircuitFG
May 18, 2006 06:55 PM
SOHC_MShue
Mar 1, 2005 05:42 AM
delsolrob
13
Dec 3, 2003 08:50 PM
bronzehatch
Jul 22, 2002 02:27 PM
