16 Ohm injectors?
Old May 7, 2002 | 10:45 PM
Shaun K's Avatar
Default 16 Ohm injectors?
I got a hold of some RC 440cc injectors this weekend, and I tested them with a Fluke multimeter. They all came out to 16.3 Ohms putting one probe on each injector pin. What's the deal here, are these saturated injectors? I don't think I can use these on my Hondata since the ECU needs to see 8-10 Ohms. Any ideas?
Old May 7, 2002 | 11:08 PM
Sonny's Avatar
Default Re: 16 Ohm injectors? (Shaun K)
Yes, they are saturated. That is what mine read (16 ohms). The stock Honda ones that I had before were all 12 ohms. Those injectors will work fine with the Hondata. I used that exact setup with very good results.
Sonny
Old May 8, 2002 | 12:35 PM
Shaun K's Avatar
Default Re: 16 Ohm injectors? (Sonnyballs)
Cool, thanks for the info. Now all I need is an OBD1 P72.
Old May 8, 2002 | 01:34 PM
Sonny's Avatar
Unless you have GS-R and want the secondary runner to work, any OBD1 ECU will work fine...P28, P06, P74, P75...I've run almost all of them. The P72's added knock sensor ability is worthless. If you want real knock control, buy a cheaper OBD1 ECU and get a Classic J&S Safeguard. I had a P28 for awhile and then a P75 with my Classic J&S and it made tuning my 4B setup very easy.
Sonny
Old May 8, 2002 | 03:12 PM
Shaun K's Avatar
yup, I have a GSR. I'll keep the stock intake manifold for now, it's cheaper than buying a P28, a new intake manifold, and making a new charge pipe.
Old May 8, 2002 | 03:18 PM
Sonny's Avatar
Ok...good luck though. The OBD1 P72 is a high sought after ECU and price gouging is very common. If you opt to go with a P28 or something (they're usually about a 100 bucks), the butterfly will stay in the "high rpm" mode.
Cool sig BTW.
ZZ
Sonny
Old May 8, 2002 | 05:12 PM
SiRkid's Avatar
i have a p72 that i picked up cheap! dude just wanted to get rid of it!
pcbabb
Jan 11, 2013 01:35 PM
hybridb18
Dec 30, 2010 06:20 PM
jdmtim
Sep 10, 2004 02:25 AM
hypa
May 20, 2003 03:48 AM
FOrSfEd
May 15, 2002 08:08 AM
