turbo sohc
Old May 9, 2002 | 03:35 AM
MCNease's Avatar
Default turbo sohc
Ok, I was gonna get a B16 to swap with my stock sohc VTEC d-series engine (I have a '96 Honda Civic EX). But that is pretty expensive considering I also want the DRAG III kit. I figure I'm gonna run with the sohc I have, and put the turbo on that. But, I'm wondering if I'll get decent boost with it. Anyone got an answer??
Old May 9, 2002 | 03:55 AM
maxim's Avatar
Default Re: turbo sohc (MCNease)
You can run about 14psi off of the d16 block with a good fuel management system(Hondata), larger injectors, in tank fuel pump, GE rods, and JE pistons without any sleeving or building of the block. I am running 7.5-8psi right now without any of those things mentioned above except for the Drag kit.
Old May 9, 2002 | 03:56 AM
rjardy's Avatar
i dont see a problem with you building boost........
am i missing something?
ROB
Old May 9, 2002 | 06:05 AM
VTC_CiViC's Avatar
Well, you'll get as much boost as you want really. As far as what your motor will take, It really depends how you fuel it. If you spend the $$ and do it right the first time (Hondata etc..), I'd say 10-12psi max on those sleeves before I'd worry about splitting something. I've run upwards of 1bar+ on my D16 before, held up great with the 440's and AFC trick, but I certainly wouldn't run this on a daily basis.
pliskin679
Nov 24, 2007 03:44 PM
FuRiO27
May 12, 2005 08:52 AM
HT Username
Feb 27, 2005 09:05 PM
lazycoEX
Feb 14, 2003 06:26 PM
MCNease
May 8, 2002 04:34 PM
