Which Turbo is bigger?
Old May 8, 2002 | 02:15 PM
B20bTurbo's Avatar
Default Which Turbo is bigger?
Is the 60-1 turbo bigger than the t3/t4e exhaust .63 stage 3 with .60 compressor housing. Im a little confused about the difference in sizing between them. TIA
Old May 8, 2002 | 02:27 PM
TurboSedan's Avatar
New User
Default Re: Which Turbo is bigger? (B16aTurbo)
The 60-1 is bigger.
Old May 8, 2002 | 02:28 PM
degradated's Avatar
New User
I'm pretty sure the 60-1 is way bigger than that, but let's wait for the experts to step in here...
Old May 8, 2002 | 02:35 PM
B20bTurbo's Avatar
Default Re: Which Turbo is bigger? (degradated)
thx, i was wondering about that, it's just the compressor side right, the exhaust sides are the same on both right? is there a bigger trim for the t3/t4e to make it as big as a 60-1 satying with the .63 exhaust trim?
Old May 8, 2002 | 02:45 PM
paulzy's Avatar
not neccesarily...turbonetics uses a .60 a/r comressor housing for their hifi 60-1....but the standard 60-1 turbos use a .70 a/r housing with a 4' inlet and 2.5" outlet....
EDIT: That's the exact same turbo as mine...
I have a .63 a/r turbine housing, stage 3 wheel, 60-1 compressor wheel, .70 a/r comrepssor housing...
I can get you one for 600 bucks shipped brand new
[Modified by Slow_ass_4dr, 3:46 PM 5/8/2002]
Old May 8, 2002 | 04:03 PM
B20bTurbo's Avatar
Default Re: Which Turbo is bigger? (Slow_ass_4dr)
Aren't there fitment issues with using the 60-1 with like a drag manifold? Did you have to cut a lot away of the block to get it to fit? It would be for a b16a.
Old May 8, 2002 | 04:19 PM
Jared's Avatar
Doesn't Turbonetics make a 60-1 HiFi as they call it which is basically a 60-1 that bolts to a T3 flange?
Old May 8, 2002 | 04:39 PM
paulzy's Avatar
There will most definately be fitment issues with the drag manifold and 60-1 combo...just needs a little more grinding !
Jared: Turbonetics calls that the 60-1 hifi.....it does not have a 4" inlet and 2.5" outlet like the larger housings...pretty nice too....I can also get you this turbo too
Old May 8, 2002 | 08:30 PM
earl's Avatar
Default Re: Which Turbo is bigger? (Jared)
60-1 had a 4" inlet while 60-1 hifi is about 2 1/2 and flows at least 10% less
Old May 8, 2002 | 08:56 PM
paulzy's Avatar
Default Re: Which Turbo is bigger? (earl)
Earl, you guys go out to the track again yet? So any new BIG sponsors?
Old May 8, 2002 | 10:11 PM
saso
Guest
Posts: n/a
I have a 60-1 hifi ball bearing on my b16 on a drag 2 manifold no fitting probs bolts right up.
Sunlight
Apr 6, 2005 10:04 AM
Tchleung
Jul 23, 2004 12:49 PM
underpressure02
Feb 10, 2004 07:26 AM
B00STeD
Aug 21, 2002 03:59 PM
1fstevo
Mar 18, 2002 10:46 PM
