bouncing off rev limiter w/ forced induction
Old May 8, 2002 | 10:21 AM
90EF8si's Avatar
Default bouncing off rev limiter w/ forced induction
How bad is this for your engine? Is it worse to do this with a turbo than it would be if you were n/a? And are two stage rev limiters bad for your engine, just sitting there bouncing of rev limiter before you launch?
Old May 8, 2002 | 10:22 AM
EP3_05's Avatar
Default Re: bouncing off rev limiter w/ forced induction (90EF8si)
The factory rev limiter is a fuel cut which is bad either if you have n/a or fi. But it can be more catastrophic with a turbo, supercharger, or nitrous. A two stage revlimiter from what I understand is a spark cut which is much better for the motor.
Old May 8, 2002 | 10:23 AM
sushibug's Avatar
as for hitting the rev-limiter, i asked that question maybe a week or less ago. the question was.... yes its very very bad.... so don't miss-shift.
Old May 8, 2002 | 11:38 AM
rtype11's Avatar
you shouldnt hit the "fuel limiter", spark limiter is okay so set your msd 100rpm before stock cutout or get an ECU rechipped/standalone.
P.S. this is for the unconventional thinkers only: fuel cut in a turbo car is no problem at all, it drops all the fuel to cylinders individually. So there will be no fuel at all in one cylinder at a time, so there is absolutely nothing to detonate.
Old May 8, 2002 | 11:40 AM
jinxproof99's Avatar
New User
well i bang off the rev limiter in 1st and 2nd at about 9600 rpms every pass i make and i've never had a problem. i wonder why??
Old May 8, 2002 | 11:54 AM
c_penson's Avatar
Default Re: bouncing off rev limiter w/ forced induction (jinxproof99)
I dont recomend hitting the stock rev limiter because it leans out the engine and before the head is completely dry of fuel there is detonation because o the lean condition. Beacuse of the high revs you dont hear the detonation and this can cause damage if done often.
Old May 12, 2002 | 11:14 AM
IMPORTDYNAMICS's Avatar
Default Re: bouncing off rev limiter w/ forced induction (c_penson)
I cracked all 4 of my ring lands on stock pistons when I hit the factory rev limiter!! If you have your motor perfectly tuned for highest HP, It is the most dangerous to hit rev limit. A perfectly tuned car is going to have higher comp pistons, furthur advance on ignition and a leaner a/f ratio so rev limit is VERY bad!! If you are worried, run lower comp ratio pistons, retard your timing more, use a intercooler and make your fuel curve stay below 12 a/f/r and use highest octane gas possible then you probably could be ok to hit rev limit. Oh yeah forged pistons help too!!!
Old May 12, 2002 | 11:18 AM
Jared's Avatar
Default Re: bouncing off rev limiter w/ forced induction (IMPORTDYNAMICS)
As someone mentioned above, I really suggest an ignition cut rev limiter as well. That's what I'm using on my E6K and it works great.
Old May 12, 2002 | 05:57 PM
degradated's Avatar
New User
There was some dude in a turbo civic at the track yesterday that was doing this. Every time he did a burn out in the water pit, he would sit there in 1st gear and it would ping against the limiter - ping ping ping 20 times. The wheels weren't even spinning that good. He should have done it in 2nd gear and controlled the rpms to not bounce up like that. Argh, I'm suprised he didn't blow something in his motor that day. And shifting down the track he was bouncing off the rev limiter.
Old May 12, 2002 | 06:06 PM
SiRkid's Avatar
Default Re: bouncing off rev limiter w/ forced induction (degradated)
hmmmm....ive got stock ignition and hondata(on my 00 si) ......im afraid to hit the stock limiter..is it ok?? or should i upgrade???? i think it is bad but some people say its ok
geeman640
Honda Civic (2006 - 2015)
13
Oct 5, 2007 12:00 PM
UberTeg
Feb 4, 2003 08:59 AM
htludernewbie
Aug 25, 2002 03:06 AM
4wsB21a
Feb 4, 2002 12:44 PM
ben_vtec
Nov 21, 2001 04:42 PM
