Hondata question
Old May 7, 2002 | 06:53 PM
johnmay19's Avatar
Default Hondata question
Getting ready to get a hondata 2b. My question is my gsr ecu has a code 13, which I know says to replace with known good ecu. Car runs fine though. So I am wondering if I should get the p72 setup for hondata or don't risk another problem and get a p28(I know I won't have a knock sensor and I have a skunk manifold so secondary control doesn't matter). TIA
Old May 7, 2002 | 07:29 PM
ekb18c's Avatar
Default Re: Hondata question (johnmay19)
p72 is a great ecu!! Well your code 13 may have nothign to do with your ecu but rather a sensor. Code 13 if I'm not mistaken is the BARO Sensor (atmospheric pressure). It could be just a broken sensor or a unplugged sensor. My advice to you is to keep your p72. However if you are still convinced that the p72 is a bad ecu then you should just sell it to me for dirt cheap! Let's say I buy the p72 off your for 20 bucks?
Old May 7, 2002 | 07:32 PM
sgT's Avatar
sgT
Default Re: Hondata question (ekb18c)
If you are getting the code for BARO sensor, then you need to replace the ECU.
The BARO sensor is INSIDE the ECU.
Old May 7, 2002 | 08:41 PM
VaporTrail's Avatar
New User
Default Re: Hondata question (sgT)
Yes, but Doug@hondata says the car will run just fine without the baro sensor. Map sensor tells the computer the same information.
Old May 8, 2002 | 10:47 AM
johnmay19's Avatar
Default Re: Hondata question (VaporTrail)
Thanks for the help
Old May 8, 2002 | 10:49 AM
VTC_CiViC's Avatar
Yea I had a code 13 on my Civic for ages, ran fine.
Old May 8, 2002 | 11:50 AM
DirtyLude's Avatar
Default Re: Hondata question (VTC_CiViC)
On a MAP based system the baro sensor only makes very minor corrections to a/f. You'll hardly even notice its not there.
Old May 9, 2002 | 12:58 PM
o_Rage_o's Avatar
Default Re: Hondata question (DirtyLude)
No experience here, but if it's a baro pressure sensor and the map sensor gives about the same info, the adjustments to you a/f should indeed be minor (unless atmospheric pressure changes a huge amount one day which it does'nt, usually it sits around 101.3 +- a bit)
Randomnoob
Apr 7, 2019 09:21 PM
sackdz
Engine Management and Tuning
Sep 29, 2009 06:14 AM
88 EF Hatch
Sep 12, 2009 08:32 PM
rev limiter
Mar 6, 2005 10:36 AM
B18Flip
Oct 28, 2002 05:53 PM
