? about spool up time
Old May 7, 2002 | 06:49 PM
unknown user's Avatar
Default ? about spool up time
im debading on which turbo size i should use on my B16.
T3/TO4E .57 Trim, Stage 3 wheel.
should I go with .63 A/R or .48 A/R?
when does it start to spool up and when does it hit full boost on both of these on stock B16?
Old May 7, 2002 | 06:53 PM
dustin's Avatar
Default Re: ? about spool up time (unknown user)
Nobody that wants to make power wants a .48 turbine housing...oh the ugliness
Old May 7, 2002 | 07:05 PM
Default Re: ? about spool up time (dustin)
when does .63 A/R hit full boost?
Old May 7, 2002 | 07:12 PM
dustin's Avatar
depends on the motor, compressor, boost level
Old May 7, 2002 | 07:15 PM
I stated above,
Stock B16A2
Old May 7, 2002 | 07:20 PM
dustin's Avatar
I stated above
depends on motor, compressor, boost level
Old May 7, 2002 | 07:23 PM
MiraiZ's Avatar
I stated above
your avatar is soooo true ...T_T
Old May 7, 2002 | 07:33 PM
JM Performance's Avatar
Is the power output that different? For the entire band or most top end.
Old May 7, 2002 | 07:39 PM
degradated's Avatar
New User
Was around 4000 rpms on my B18b I think. It went down a bit after I put in the 3" exhaust...
It's really not that bad, the time you have to wait for it to spool is well worth it.
Old May 7, 2002 | 07:51 PM
intekragsr's Avatar
Default Re: ? about spool up time (degradated)
i got the same turbo. I hit full boost (5psi for now) at around 3500 rpm
Old May 7, 2002 | 07:54 PM
tonydatyga's Avatar
Default Re: ? about spool up time (MiraiZ)
I stated above
I wouldn't use a $1 bill though, still
Old May 7, 2002 | 07:55 PM
racerxadam's Avatar
i'm interested too. t3/t40e 57 trim .63 A/R stage 3 wheel on a stock b16 @ 8psi. anybody have a good guess.
Old May 7, 2002 | 09:07 PM
Etylorcen's Avatar
Default Re: ? about spool up time (racerxadam)
Stock exhaust? With the 2.5'' downpipe? Probably like 4500.
yessewey
Feb 19, 2010 08:50 AM
PeakBoost
Jan 25, 2006 03:17 PM
DARKON
Apr 3, 2005 06:33 PM
LSVtechnologytur...
Nov 18, 2004 11:22 AM
