Tell me what you guys think of my TURBO setup::
This setup is for a 2001 Prelude SH
Here it is, if you see anything that i should change/add/ or delete, please mention it in your post, dont be critical:
Turbonetics ceramic ball bearing turbo T3/T04E
Kiwi Manifold
Hondata Stage 2
JE 9.5-1
RC 720 cc
3" intercooler piping
HKS ss bov
Tial 35mm wastegate
Spearco Intercooler
Crower Rods / Crower valve springs and tit. retainers.
Golden Eagle block sleeves
NOS or Bosch fuel pump - WHAT BRAND/SIZE
MSD ignition 7 series
J&S safeguard
Crower T cams
STR Cam gears
Thermal 3” Downpipe
EXHAUST - WHAT BRAND
Clutch Master stg 4
JRSC oil cooler
AEM fuel rail and FPR
what plugs and wires???
what kind of pulleys
possibly a 97 Accord LS tranny
Suspension: H&R springs with KOni Adj. and neuspeed strut bars
Kiwi Manifold
Hondata Stage 2
JE 9.5-1
RC 720 cc
HKS ss bov
Tial 35mm wastegate
Spearco Intercooler
J&S safeguard
Crower T cams
STR Cam gears
Thermal 3” Downpipe
Clutch Master stg 4
JRSC oil cooler
New User
Re: Tell me what you guys think of my TURBO setup:: (showlude)
Crower T cams
Crower T cams
3" IC piping, not required, Thermal does not make a 3" downpipe or exhaust, nobody makes a 3" system except maybe brullen on a custom request.
Just have the exhaust/DP fabbed somewhere local. Kiwi manifold, you have a source for one?
Plugs-ngk zfr7f's
wires-stock/msd
exhaust-custom
downpipe-custom
fuel pump-bosch
pulleys-don't bother
LS tranny-don't bother
What trim is the turbo?
Plugs-ngk zfr7f's
wires-stock/msd
exhaust-custom
downpipe-custom
fuel pump-bosch
Re: Tell me what you guys think of my TURBO setup:: (apexii)
I dont know wich trim compressor or stage or any o that stuff? What would be the best for fast spooling and reliabiluoiyt
Make sure you get those ARP headstuds!
*holding breath*
*holding breath*
what computer do u plan on using?
Re: Tell me what you guys think of my TURBO setup:: (ek9t)
No they still are not out yet, but rumored to be out very soon. I spoke to a vendor at etown regarding them, he already has 3-4 orders taken. I will hopefully get a set also when available, hopefully within the next few weeks.
Re: Tell me what you guys think of my TURBO setup:: (Prelude_RCR)
1994-1997 accord ls is a trim level for an accord, someone told me that that tranny will be better for me...but i dont know? the trim on the turbo is t3/tO4e
I first put a turbo on my car that was intended for an integra, came from a drag3 kit for an ITR... The compressor trim was .57 and ended up being way too close to the surge limit, and ended up needing a rebuild within 6-8months..
You can distinguish the trim levels by looking at the numbers on the compressor housings, and counting the blades also may indicate something further.
Make sure you know what you're getting, before you get it. You will surely want an a/r of .63 or higher.
Mike
And doesn't the SH come with ATTS?
