Injector clips
Old May 7, 2002 | 10:43 PM
SlowB16's Avatar
Default Injector clips
I need to put my Prelude injectors (290cc) on my first gen b16. Where do I get the correct clips? And do I need to change from the 12:1 disk I have in there right now with the stock injectors? Thanks guys.
Old May 7, 2002 | 10:44 PM
SlowB16's Avatar
Default Re: Injector clips (SlowB16)
Oh and what car can I take the clips off of or do I need to buy them new? And how do I wire them in? Thanks again
Old May 7, 2002 | 11:09 PM
Sonny's Avatar
The 1st gen B16A uses peak and hold style (low impedance) injectors. Unless you've removed the resistor box, you don't want to run those 290cc Prelude injectors (they are high impedance) in that car.
Sonny
Old May 8, 2002 | 09:20 AM
SlowB16's Avatar
Default Re: Injector clips (Sonnyballs)
I use an OBD1 p30 ecu so it should be fine I think. Correct?
Old May 8, 2002 | 09:21 AM
tararan's Avatar
if you go to a junk yard, injector clips from GM cars will work. or older hondas...
i got mine off of a Geo Storm.. fits perfect..
Old May 8, 2002 | 03:17 PM
SlowB16's Avatar
Default Re: Injector clips (tararan)
So what about the wiring? Is it just one color to the same color, or is it more complicated?
Nathan_volcom
Feb 19, 2008 08:38 PM
Mike95lude
Jan 14, 2008 11:29 AM
f1 vtec
Feb 16, 2006 07:57 AM
Panoply
Jul 19, 2005 01:37 PM
Panoply
Jul 18, 2005 09:36 AM
