Need help quick, in the middle of an install!
Old May 7, 2002 | 04:44 PM
OKSolSi's Avatar
Default Need help quick, in the middle of an install!
I was installing the new 450 injectors I got and when I took off the fuel rail some gas spilled out onto my still warm intake manifold and LUCKILY it only evaporated. I was fucing lucky. I'm guessing since my engine wasn't cooled down all the way, fuel pressure was still in the system? I quickly snapped on the fuel rail before anymore spilled out.. how long until the sytem's fuel pressure drops? Please respons so I can finish my turbo installation! Thanks in advance.
Old May 7, 2002 | 04:50 PM
dustin's Avatar
Default Re: Need help quick, in the middle of an install! (OKSolSi)
If you pulled the rail off there isn't any pressure left. That doesn't mean the fuel that was in the rail and lines disappeared though.
Dustin
Old May 7, 2002 | 05:49 PM
LS-G's Avatar
just wait for the engine to cool, then disconnect it. Not a whole lot of fuel will come out.
Old May 7, 2002 | 05:56 PM
2K_TEG's Avatar
Default Re: Need help quick, in the middle of an install! (LS-G)
I don't think your IM will get hot enough to ignite the fuel. Just mop it up with a shop rag, you'll be fine.
Old May 7, 2002 | 08:15 PM
tonydatyga's Avatar
Default Re: Need help quick, in the middle of an install! (2K_TEG)
hahaha, believe it or not you'd have bigger problems if it was
Old May 7, 2002 | 08:30 PM
intekragsr's Avatar
Default Re: Need help quick, in the middle of an install! (tonydatyga)
i think u open the gas cap to relieve pressure, but thats too late for you now. Dont worry, you will not catch on fire. I drove half a mile with a hot engine with half a tank of gass shooting out of my FPR once, and i didnt die. Almost from the fumes though.
Old May 7, 2002 | 10:12 PM
ion_four's Avatar
Default Re: Need help quick, in the middle of an install! (94hondahybrid)
Yeah, you just have to take off the gas cap to relieve the pressure. There's not much fuel in the rail, anyway, so once maybe a couple ounces comes out of the rail that should be all and by the time you get done it'll be gone.
eg64u
Aug 16, 2007 05:10 AM
Bantam
Mar 7, 2003 08:58 AM
thehondaguru
Oct 11, 2002 05:33 AM
digitalspice
Dec 18, 2001 07:57 AM
laughinxxx
Nov 14, 2001 10:25 AM
