how to read air/fuel ratios?
Old May 6, 2002 | 03:33 PM
ceemarun's Avatar
Default how to read air/fuel ratios?
a lot of posts say that certain fmu's are 12:1 or how people should run 8:1 or whatever. all i know is that it means parts of fuel to air. is there a general principle on what ratio is good under what situations and whats considered hazardous under other circumstances?
Old May 6, 2002 | 03:40 PM
sushibug's Avatar
Default Re: how to read air/fuel ratios? (ceemarun)
a 12:1 fmu adds 12 pounds of fuel per pound of boost. tell us your current or planned setup so we can tell you what size fmu to get. generally if you are running stock injectors a 12:1 fmu is required. if you run 310cc injectors you can go 8:1. and so on.
Old May 6, 2002 | 05:50 PM
ceemarun's Avatar
Default Re: how to read air/fuel ratios? (sushibug)
im planning on just getting whatever the standard drag gen 3 kit comes w/ for a gsr.
Old Aug 25, 2005 | 04:47 AM
djnikko's Avatar
I have a euro CRX turbo running 6PSI of boost, a 255lph fuel pump, B&M FPR, 450DSM injectors, what ratio should I be lookign to run?
This thing is running way to rich judging by the plugs and smell
I have a wideband sensor and reader but on idle the reading is all over the place.
Would people say those injectors are way too big? Any other suggestions?
Thanks
Old Aug 25, 2005 | 04:50 AM
elpiar's Avatar
Default Re: how to read air/fuel ratios? (djnikko)
Chip your ECU and use Uberdata to tune, throw away that FMU
Old Aug 25, 2005 | 05:23 AM
EBP.EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">I have a euro CRX turbo running 6PSI of boost, a 255lph fuel pump, B&M FPR, 450DSM injectors, what ratio should I be lookign to run?
Thanks </TD></TR></TABLE>
you dont run fmu's with 450cc's or bigger. fmu's add more fuel per pound of boost.
Old Aug 25, 2005 | 05:41 AM
djnikko's Avatar
Default Re: how to read air/fuel ratios? (1slow4dr)
I dont have an FMU? Just a universal B&M fuel pressure regulator, is that the same? I thought there was a slight difference?
Now Ive cut up my stock fuel rail do I just buy another one or can it be used still?
Thanks
Old Aug 25, 2005 | 05:48 AM
boosted k20's Avatar
Default Re: how to read air/fuel ratios? (elpiar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar &raquo;</TD></TR><TR><TD CLASS="quote">Chip your ECU and use Uberdata to tune, throw away that FMU</TD></TR></TABLE>
BEST advice in the thread!
Old Aug 26, 2005 | 01:33 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">I dont have an FMU? Just a universal B&M fuel pressure regulator, is that the same? I thought there was a slight difference?
http://home.mn.rr.com/keebler65/honda/
Go to that above site and read the part about chipping your ECU, then read the part about datalogging. Then go to the http://www.pgmfi.org forums and download Uberdata or Crome.
wzcb08
May 11, 2003 07:36 PM
SIK IN DA HED
Oct 2, 2002 08:41 PM
SIK IN DA HED
Sep 28, 2002 12:57 PM
BoostedD15B7
Sep 26, 2002 01:15 PM
FBP Ex-T
Feb 16, 2002 04:39 PM
