Oil return line
Old May 7, 2002 | 09:59 PM
a z n t a k's Avatar
Default Oil return line
Just installed my drag 3 kit last week and I was thinking about the oil return line. I saw online somewhere that the rev-hard/max-rev kit came with a better designed oil return system. It consisted of nipples and steel braided hoses as opposed to the drag kit which has a L-shaped metal pipe connected to some rubber hose.
My question is, those of you with rev-hard/max-rev kits, where can I get the oil return plumming?
Thanks,
azntak
Old May 7, 2002 | 10:01 PM
Trigun's Avatar
Default Re: Oil return line (aZn TaK)
https://honda-tech.com/zerothread?id=67146
https://honda-tech.com/zerothread?id=109160
https://honda-tech.com/zerothread?id=114490
http://www.anplumbing.com
Old May 7, 2002 | 10:06 PM
Default Re: Oil return line (Trigun)
thanks!
Old May 7, 2002 | 10:23 PM
2K_TEG's Avatar
http://www.amstreetrod.com/index.html
Old May 8, 2002 | 03:41 PM
Default Re: Oil return line (2K_TEG)
I just bought the following parts:
1. (2) 45 degree -10 female swivel-seal Part # 804610
2. (1) 1/2" to -10 adapter Part # 981610
3. 2ft -10 stainless steel braided hose
I have a question though, what size fitting do I get for the oil pan? (the fitting that needs to be welded onto the oil pan)
Thanks...
Old May 8, 2002 | 04:03 PM
maxim's Avatar
Depends on what type of oil pan you have. I have a 2000 Civic EX with a cast aluminum oil pan, so I had to get an aluminum -10 AN weld fitting(#997110 @ http://www.bakerprecision.com).
But, if you have a steel oil pan you need the 5/8" or -10AN steel weld fitting.
[Modified by maxim, 7:03 PM 5/8/2002]
Old May 8, 2002 | 04:23 PM
degradated's Avatar
New User
Damn....that first one was way back in the day for me, back when I didn't know anything. Haha, what an embarrassment, lol. Guess everyone starts somewhere.
Old May 8, 2002 | 05:08 PM
Default Re: Oil return line (degradated)
Is it okay to just get the -10 AN / 3/8" or 1/2" steel adapter and just tap the oil pan with that piece instead of getting the weld fitting? The reason I want to go this route is if I plan on selling the car later, I can keep the turbo kit. All i'd have to do is unscrew the fitting and plug it up with a bolt of that size.
My only concern is that this might leak. what do you guys think...? Has any one done this? what size adapter/fitting did you get?
Thanks
Old May 8, 2002 | 08:30 PM
ttt
Old May 8, 2002 | 09:46 PM
accordfreak's Avatar
i just bought this block and it included an oil return bung. Should i change it out to brass instead of aluminum??
Old May 8, 2002 | 09:59 PM
D-SPEED's Avatar
Default Re: Oil return line (accordfreak)
is that welded on or is it a bulkhead ?
Old May 8, 2002 | 10:49 PM
93LSivic's Avatar
Default Re: Oil return line (D-SPEED)
I used a bulkhead type setup--only because I couldnt find anyone to weld my weld-on fitting to the pan when I was doing the initial install. Basically I just used a 10AN union and put a 10an nut on the backside of it along with an oring and used hondabond--well, ford bond--to seal it. No leaks yet.
A pic from the top side.
Old May 8, 2002 | 10:52 PM
sushibug's Avatar
mine looks EXACTLY like that... i put a gasket on and its been two weeks and no leaks.
Old May 9, 2002 | 04:48 AM
blowncivichb's Avatar
Default Re: Oil return line (sushibug)
Isn't that mounted a little low on the pan?
Old May 9, 2002 | 01:54 PM
Default Re: Oil return line (blowncivichb)
is it really??...i want to make sure it's the correct height before i use this oil pan... anybody else thinks it's too low??
Old May 9, 2002 | 04:11 PM
maxim's Avatar
It doesn't look too low. I'm not sure(from the picture) that you could raise it up much more. You just need to make sure that the oillooks like it can drain properly and is not blocked by the oil already in the pan. Kind of a judgment call.
Old May 9, 2002 | 04:31 PM
Default Re: Oil return line (maxim)
here's another shot of the return bung
here's a bigger version of the picture..(you have to copy and paste it)
http://www.imagestation.com/picture/...d.jpg.orig.jpg
[Modified by accordfreak, 1:34 AM 5/10/2002]
Old May 9, 2002 | 05:12 PM
maxim's Avatar
From this angle it does look a little low. How much space do you have to the top lip of the oil pan. If you can, try and move it up a little just to be safe.
Old May 9, 2002 | 05:23 PM
Default Re: Oil return line (93LSivic)
93LSivic- what size bulkhead fitting did you use? (1/2" to -10AN, 3/8" to -10AN or etc...)
Thanks...
Old May 9, 2002 | 10:42 PM
93LSivic's Avatar
I used a straight -10AN union. I put a -10 AN nut on the back side of it, used an oring and hit it up with some rubber bond--Ford Motoco to be exact, its the same rubber bond that honda uses.
Old May 10, 2002 | 06:20 AM
00ITR #543's Avatar
93 LSivic, Did you use a 45 degree fitting into the oil pan or a straight? That seems to fit well with the maxrev dp...
Old May 10, 2002 | 12:15 PM
93LSivic's Avatar
Default Re: Oil return line (00ITR #543)
I used 2 45 degree fittings. I have extra, brand new 90's if anyone is interested.
Old May 10, 2002 | 12:25 PM
tygsr's Avatar
my oil return line with my drag is stealbraided goodrich line, yours is rubber?
Arturbo
Oct 2, 2006 08:19 AM
Bimmerman
May 5, 2005 05:46 PM
boredracer408
Nov 16, 2003 04:26 AM
b18c1-ek
Oct 21, 2001 03:21 PM
