I have no dyno, help from experience please.
Old May 6, 2002 | 04:41 PM
saso
Guest
Posts: n/a
Default I have no dyno, help from experience please.
Where I live I have no dyno nor can I get one. I just put in some skunk 2 cam gears and would like to know if any of you guys can give me a good safe setting in which to start with. The motors are a b16a. The motor is a little laggy I know good cam tunning could help this. Now I know that yall are gonna say I need a dyno put I cant get one, and would appreciate any help. The mods are below.
Thanks
Old May 7, 2002 | 08:21 PM
tonydatyga's Avatar
Default Re: I have no dyno, help from experience please. (saso)
nice setup, can't really help you other than a bump
Old May 7, 2002 | 08:28 PM
93LSivic's Avatar
Im kinda surprised that you wouldnt have a dyno available to you. From looking at your sig...I wouldnt have half that stuff on my car without any kinds of dyno tuning.
This doesnt help any I know, but Im just a little confused..
Old May 7, 2002 | 09:02 PM
B20C5 Turbo's Avatar
New User
Not to dog, but with that kind of hardware.... Well, you should be a bit faster than 13.xx. I would concentrate on tuning before you throw any more goodies at it.
To answer your question, the stock B16 cams work best at the factory setting for all around use (street/strip). If you still want more top end power, try advancing the exhaust cam up to 3 deg and/or retarding the intake cam up to 2. Keep in mind that this will make your car real laggy around town. If you are already too laggy, advance both cams 2 deg.
If you feel OK about sending me a copy of your E6K map, I will be happy to look at it and make some other suggestions.
Old May 7, 2002 | 10:27 PM
saso
Guest
Posts: n/a
Default Re: I have no dyno, help from experience please. (B20C5 Turbo)
thanks for the help I will try to send you the map .
Old May 7, 2002 | 10:36 PM
saso
Guest
Posts: n/a
the car ran a 12.9 full body with slicks, since then I have done some work... new turbo 60-1, clutch etc. Its hard tunning without a dyno.
LowBudgetBEe
Mar 16, 2011 12:12 PM
SpeedDreamz.com
May 11, 2005 11:56 AM
IgniteTeg
Sep 18, 2002 12:06 PM
Black R
Nov 29, 2001 06:44 PM
