injectors--resistorbox??/ do i need it
Old Jan 5, 2005 | 06:31 PM
CANTFAZZDISCHIT's Avatar
Default injectors--resistorbox??/ do i need it
I got some 440cc injectors for my OBD-0 crx that i am turboing, i was woundering if i need the resistor box with these mitsu. injectors, they came out of a 99gsx or just run them with out it?/
Old Jan 5, 2005 | 06:37 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: injectors--resistorbox??/ do i need it (CANTFAZZDISCHIT)
yes, youneed one if i remember correctly
Old Jan 5, 2005 | 06:51 PM
DefiantGSR's Avatar
Default Re: injectors--resistorbox??/ do i need it (wantboost)
dont obd0 CRX come with a resistor already>?
Old Jan 6, 2005 | 12:27 PM
Default Re: injectors--resistorbox??/ do i need it (DefiantGSR)
they do come with it but i thought it was because of the high voltage needed to be regulated, i dont know if the mitsu's do?
Old Jan 6, 2005 | 01:40 PM
TunerToys's Avatar
The best answer is to mesaure your currently running injectors. In Hondas, they will be 2-4 Ohms for Low Impedance, or 10-12 Ohms for High Impedance. Most blue topped DSMs are low impedance, they will work without a resistor box, if your car already has low impedance injectors and a factory resistor box (which were often used on the Si models). If you have high impedance stock injectors, and want to install low impedance DSMs, then you need to add resistance.
BTW for OBD0 cars like the 88-91, high impedance injectors were used on most models, while the Si always used low impedance and a resistor box.
That help?
Craig @ Tuner Toys
Old Jan 7, 2005 | 04:32 PM
Default Re: injectors--resistorbox??/ do i need it (TunerToys)
it was a dx, now with a b16a and has been converted to the four injector set up, (HA SPORT) so i guess that it is wired for the Si, and they are the blue top dsm injectors. i think it should be ok to use it?
Old Jan 7, 2005 | 05:54 PM
TunerToys's Avatar
In that case, I would definitely measure your current injectors, and match their impedance. After doing swaps and mods, you really don't want to take chances....
Here is a link to show you just what to measure....
http://stores.ebay.com/Tuner-T....html
MurtazaDSM
Mar 21, 2012 12:14 PM
Steeve_Civic
Dec 4, 2011 10:11 AM
columbushatch
Jan 17, 2009 11:08 AM
DrivinVtec
Sep 17, 2007 10:08 AM
the.hamburglar
Aug 12, 2007 07:41 PM
