Oil Line Kit. Whats Missing Here? *PICS*
I bought this kit USED/NEW, was only $30 so I didnt even ask any questions was told it was a T3 feed/return kit but I dont think its all here
[img width=800 height=600]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wNzIwMjAzNnM0MTNkZmQzMXk1NDE%3D.jpg[/img]
[img width=800 height=600]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wNzIwMjAwNnM0MTNkZmQzMXk1NDE%3D.jpg
Now I thought that blue fitting should fit into that adapter[/img]
Just looking for someone to tell me how everything is going or what Im missing. Feed looks to be all there but I dont know about the drain at all
Thanks
pics might not work, Im trying to resize them
Thanks
Re: Oil Line Kit. Whats Missing Here? *PICS* (W O T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">I bought this kit USED/NEW, was only $30 so I didnt even ask any questions was told it was a T3 feed/return kit but I dont think its all here
NowIthoughtthatbluefittingshouldfitintothatadapter
Thanks
pics might not work, Im trying to resize them</TD></TR></TABLE>
Modified by SHystrdyGSRtdy at 12:10 PM 1/6/2005
Thanks
Re: Oil Line Kit. Whats Missing Here? *PICS* (civic123)
ya thats why I wanna resize them lol, there like 2056X1700
And when you make them a tolerable size they are good quality
EDIT- i know HOW to resize them in paint or whatever, but here at work we cant save files to a hard drive, so I load em right off the camera to the WTDR so and tell me the code
Modified by W O T at 12:58 AM 1/6/2005
TSPeed Factory
that looks like everything you would need for an oil feed line. you even have the adapter with a 1/8 bspt thread .
Re: Oil Line Kit. Whats Missing Here? *PICS* (AzntaggeR)
And Im assuming this fat ******* line (like 3/8" inner diameter) is for my return?
I dont have my turbo in my hands yet so I dont get what the return line clamps to or how Im supposed to attach it to my oil pan, but Ive got lots of barbed fittings and such at my work, just need to know what Im missing
Whats the blue fitting though?
looks like you got two lines? a skinnier one and a bigger one.. the return should be the bigger one (check if it's -10an in size - not sure how they measure it but compare with another one that is a known -10an in size to make sure)
and the one with the oil pressure sensor with the hole is your feed line.. the adapter thing that looks like a plate with the two bolts in is your oil return fitting that goes onto the turbo...
Modified by SHystrdyGSRtdy at 12:55 PM 1/6/2005
Re: Oil Line Kit. Whats Missing Here? *PICS* (SHystrdyGSRtdy)
it looks like you have everything you need for the feed, the return looks incomplete,
the fitting that hooks up into your drain hose that connects to the bung in your oil pan, and the fitting that hooks your drain hose to your drain flange on the turbo(i have an extra one of these),
i will send you 10 bucks for the oil sender though, i broke the tip off mine and i need a new one
I will post up the stuff i have tonight if you will hook me up with that switch!
Re: Oil Line Kit. Whats Missing Here? *PICS* (slowpokesi)
so does anyone know what this blue fitting is for?
I already got a piece to weld onto the oil pan and then clamp the oil return onto but I dont think I have the fitting that goes into the turbo that the drain line clamps to, unless its already on the turbo... which it very well might be
that blue part goes into the back of the block, then the brass t fitting screws into that, that blue part is needed otherwise you will strip the back of the block since that brass t fitting uses diffrent threads, think of it as a thread converter.
Here are the parts i can send you for free if you hook me up with that switch.
you need something like that gold fitting to go into your drain flange, the toher blue fitting thats attached to the hose hooks into the that peice.. then you need a fitting for you oil pan, and a fitting for the other end of the hose too hook up into your oil pan, like in this picture,
Modified by slowpokesi at 9:30 AM 1/7/2005
CVC9216
09-11-2005 11:11 PM
