muffler shop downpipe.
Old Jan 5, 2005 | 09:30 PM
chihuahuamanx's Avatar
Default muffler shop downpipe.
what would it cost to have this done. I wanna buy my pipes from whitey, then cut then and getem welded.
also, where can I get a flange for an sc61, and what exactly is it called (its a five bolt, but i need the right one)?
also what do i do for a flex pipe? are they really nessicary.
this is going on a prelude, thanks.
Old Jan 5, 2005 | 09:51 PM
turtle-eg's Avatar
Default Re: muffler shop downpipe. (chihuahuamanx)
Some muffler shops won't even touch it because it's too time consuming and some shops don't know what to do.... But if they're willing to do one for you from scratch, it'll probably run you plus or minus 200, so it might be better to buy a pre-fabbed downpipe.
If u wanna go the cheaper route, just buy some ubends and make the pipe yourself. Just have the muffler shop weld it up for you.
YOu can buy the flange a cheapturbo.com
Old Jan 5, 2005 | 10:34 PM
Default Re: muffler shop downpipe. (turtle-eg)
anyone know where i can get a 3inch flexpipe?
Old Jan 6, 2005 | 12:43 AM
project dc2's Avatar
i got 3" flex pipes for 50 bucks and the 5 bolt flange for 25$
Old Jan 7, 2005 | 10:59 AM
Default Re: muffler shop downpipe. (project dc2)
should the muffler shops have the flange to attach to my cat?
Old Jan 7, 2005 | 11:31 AM
95GSRTT
Guest
Posts: n/a
SHOULD but doesnt mean they will
Old Jan 7, 2005 | 11:34 AM
Default Re: muffler shop downpipe. (95GSRTT)
yea, good point. Ill check w them before hand.
Old Jan 7, 2005 | 11:43 AM
Bailhatch's Avatar
they will i bet. a standard 2.5" 2 bolt flange bolts right up to a stock honda cat. they cost less than $4 ea at Midas near me.
Old Jan 7, 2005 | 11:47 AM
Default Re: muffler shop downpipe. (Bailhatch)
what about for a 3" downpipe onto a cat?
Old Jan 7, 2005 | 11:50 AM
plus i need to weld it onto my flexpipe.... will that be a problem?
Bailhatch's Avatar
into a 3" cat? then you need a 3" flange. into a stock cat...well thats just sad
Old Jan 7, 2005 | 11:52 AM
well ive known allotta people w 3 inch dp's that run to stock cats, how do they do it?
Old Jan 7, 2005 | 12:00 PM
95GSRTT
Guest
Posts: n/a
You can do it, but it just ruins the point of having a 3" downpipe. All that exhaust that is flowing through a 3" and is gonna have to be jammed into that, what?, 1 3/4" cat and its gonna HEAVILY restrict flow. Its possible, but you mine as well get a 2" downpipe if you stay with a stock cat.
Old Jan 7, 2005 | 12:21 PM
EJ1 wilcox's Avatar
I cut and fit all my own pipes with a sawzall and then took them into a muffler shop to get welded up...
I had everything all marked and ready to go so it only took them about 45 min to weld it all up...
They only charged me $30 ( plus another 10 that I tiped to the welder) to weld up my charge pipes, downpipe, and dumptube!
And they did a great job! Can't beat DIY!
Old Jan 9, 2005 | 12:02 PM
Default Re: muffler shop downpipe. (EJ1 wilcox)
this might be a lil off topic, but do you really think getting a 3"dp is useless w/ a stock cat?
Donkey85
Feb 16, 2004 05:01 AM
spoon23_JDizM AkA SpOoN20
Dec 10, 2003 05:15 AM
IntegD
Sep 14, 2002 09:29 PM
