difference between ZEX and NOS kits....
Old Jan 4, 2005 | 08:53 PM
mk2's Avatar
mk2
Default difference between ZEX and NOS kits....
what makes them different, better than one another??
Old Jan 4, 2005 | 10:46 PM
PrettyLude's Avatar
zex comes with a controller
Old Jan 5, 2005 | 06:52 AM
Mr. JDM-GSR's Avatar
Default Re: (PrettyLude)
i have a kit for sale(zex)
Old Jan 5, 2005 | 07:10 AM
VTC_CiViC's Avatar
Default Re: difference between ZEX and NOS kits.... (mk2)
Among other things, ZEX = dry only (afaik), NOS obviously you can go wet or dry. ZEX also has that FPR adjustment thingy, adjusts fuel pressure to compensate for N2O pressure.
Old Jan 5, 2005 | 07:30 AM
t3h_sl0w's Avatar
Default Re: difference between ZEX and NOS kits.... (VTC_resurected_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_resurected_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Among other things, ZEX = dry only (afaik), NOS obviously you can go wet or dry. ZEX also has that FPR adjustment thingy, adjusts fuel pressure to compensate for N2O pressure.</TD></TR></TABLE>
ZEX makes a wet kit......
Old Jan 5, 2005 | 08:26 AM
The Clash's Avatar
Default Re: difference between ZEX and NOS kits.... (t3h_sl0w)
A nitrous kit is a nitrous kit, really there's nothing special between either of them. The ZEX kit puts the solenoids in a pretty purple box, wires up the TPS and is actuated by throttle position (WOT). The NOS kit has exposed solenoids and uses a pedal switch but can be wired up like the ZEX, to an RPM switch, etc.
Old Jan 5, 2005 | 09:19 AM
PM-Performance's Avatar
Default Re: difference between ZEX and NOS kits.... (The Clash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Clash &raquo;</TD></TR><TR><TD CLASS="quote">A nitrous kit is a nitrous kit, really there's nothing special between either of them. The ZEX kit puts the solenoids in a pretty purple box, wires up the TPS and is actuated by throttle position (WOT). The NOS kit has exposed solenoids and uses a pedal switch but can be wired up like the ZEX, to an RPM switch, etc.</TD></TR></TABLE>
what he said
Old Jan 5, 2005 | 02:29 PM
JSpin's Avatar
Default Re: difference between ZEX and NOS kits.... (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">
what he said</TD></TR></TABLE>
x2
i tell everyone to look into putting there own kit together. everyone is all about putting there own turbo stuff together which is obviously the way to go, and nitrous is no different.
Old Jan 5, 2005 | 04:21 PM
vtecmissle's Avatar
the zex kit ramps up the fuel pressure i dont believe the other brands do. It puts bottle pressure to the fuel pressure regulator and this adds more fuel.
Old Jan 5, 2005 | 06:50 PM
JSpin's Avatar
Default Re: (vtecmissle)
all dry systems use fuel pressure to supplement the fuel side of things
Old Jan 5, 2005 | 07:51 PM
97hb's Avatar
Zex kit took me all of 30min to install. Easy as pie. No troubles with it spraying for like 2 years Comp tested motor and its all good
XspeedSi02
Sep 28, 2008 01:04 AM
MooreBoost
Feb 18, 2004 10:18 AM
See Are X
Nov 6, 2002 07:54 PM
v-tec crx
13
Dec 26, 2001 06:19 AM
turbo_b18c
Nov 14, 2001 05:25 PM
