afc hack + emissions
Old Jan 6, 2005 | 01:01 PM
ramennoodles's Avatar
Default afc hack + emissions
i'm currently running a drag 3 turbo kit and it passes emissions just fine. I want to invest in getting an afc and some 440 injectors and use the afc "hack". would I still be able to pass emissions using this set up?
Old Jan 6, 2005 | 01:04 PM
93turbo16's Avatar
what state? It all depends on how much you have to go through. But I wouldn't see why not, if you get it tuned properly and use it on low boost only.
Old Jan 6, 2005 | 01:06 PM
Default Re: (93turbo16)
Washington state
Old Jan 6, 2005 | 03:51 PM
beepy's Avatar
Default Re: (600gixxer)
Washington State has no visual inspection. If you make stoich AFR's at idle-2000 RPM, and have a working catalytic convertor, you will pass.
Old Jan 6, 2005 | 03:52 PM
liam821's Avatar
25 Year Member
Default Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Washington State has no visual inspection. If you make stoich AFR's at idle-2000 RPM, and have a working catalytic convertor, you will pass.</TD></TR></TABLE>
I pulled off my turbo kit swapped on headers and passed cali emissions with 450cc dsm injectors and an afc. Just make sure you have a good cat and it will pass just fine.
liam
Old Jan 6, 2005 | 05:23 PM
beepy's Avatar
Default Re: (liam821)
Note: If you have OBDII, the ECU will return "Catalyst System Efficiency Below Threshold" if the catalyst system is not up to par with legal standards. It's a good guide to passing the sniffer test. No CEL, you will do fine. (Assuming you aren't using an O2 tricker to avoid the CEL)
Speed_1
Jul 14, 2008 08:06 PM
tyflip2
Jan 31, 2004 10:39 AM
T3T495GSR
Oct 11, 2003 06:59 AM
monsterb18b
Aug 28, 2003 04:59 PM
