270degree thrust bearing vs a 360 degree thrust beering
Old 01-04-2005, 10:49 AM
markvqwerty's Avatar
Default 270degree thrust bearing vs a 360 degree thrust beering
can annybody tell me what the difference is between a 270 degree thrust bearring and a 360 degree thrust bearring?
Old 01-04-2005, 11:25 AM
mochasi's Avatar
Default Re: 270degree thrust bearing vs a 360 degree thrust beering (markvqwerty)
360 is better , but i dont' know why..
Old 01-04-2005, 11:31 AM
Moderator
TheShodan's Avatar
Default Re: 270degree thrust bearing vs a 360 degree thrust beering (mochasi)
the difference is really about longevity of the turbo. Both will last about 200,000 miles or so w/o much issue, but the 360 degree bearing can take a bit more heat, a bit more punishment, and keep things running at an optimal level a bit longer
Old 01-04-2005, 12:55 PM
Default Re: 270degree thrust bearing vs a 360 degree thrust beering (TheShodan)
so its not gonna make less resistance or something?
thanks!
Old 01-04-2005, 12:56 PM
btw mochasi: k1 fan or where did you get the name from?
Old 01-04-2005, 01:33 PM
B*A*N*N*E*D
PeakBoost's Avatar
the 360* thrust bearing provides greater oiling and shaft protection under higher thrust loads. (higher boost pressures(above 16psi on a daily basis, improperly sized turbine housings, mismatched wheels, etc..)
about 90% of our customers using T3/TO4E turbos use the factory 270* thrust with zero problems.
however, when moving up to the larger compressors mated to the smaller T3 turbine sections, it is recommended to run the 360* thrust to prolong the life of the turbocharger.
we do a large amount of rebuilds on all different types of turbochargers and hardly will we see a thrust loss as cause of failure. the main cause of failure is improper oiling, or oil contamination.
hope this helps
Old 01-04-2005, 06:47 PM
mochasi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markvqwerty &raquo;</TD></TR><TR><TD CLASS="quote">btw mochasi: k1 fan or where did you get the name from?</TD></TR></TABLE>
my doggy is named mocha see the icon .. i luv him haha .. whats k1 ???
Old 01-05-2005, 02:19 AM
thanks for the replies now i know!
btw k1 is the worlds biggest fight leage
Old 01-05-2005, 03:14 AM
elinetics's Avatar
K1 rawks fave fighter is abidi. But I like pride better tho.
Old 01-05-2005, 07:45 AM
Default Re: 270degree thrust bearing vs a 360 degree thrust beering (elinetics)
abidi?? he is a cheater! cant stand him!
i like ignashovs style!
and of course peter aerts,ernesto hoost and remy!
not only because im from holland to!
i like pride also but its neve3r on the television
ashtons300zx
01-18-2013 06:59 AM
bootlegcivic
12-28-2007 04:02 PM
Quickgti1.8t
09-02-2005 10:55 AM
boosted_dc2
09-05-2003 02:01 PM
Quick Reply: 270degree thrust bearing vs a 360 degree thrust beering
