a question on rocker arms
Old Jan 4, 2005 | 07:56 PM
DXK Eg's Avatar
Default a question on rocker arms
ok heres the deal..i just installed ctr camshaft on my motor and i forgot to mark where each rocker arm came from and now it's all mess up ..are the valves close at tdc position..what can i do to fix this??? i so **** off..
Old Jan 6, 2005 | 08:49 AM
ZoRG's Avatar
Default Re: a question on rocker arms (dynasty-x-motorsport)
Put them back in and set the valve lash.
Old Jan 6, 2005 | 10:34 AM
tgreaves's Avatar
Why did you pull the rocker arms out to install cams?????
Old Jan 6, 2005 | 11:20 AM
ZoRG's Avatar
Default Re: a question on rocker arms (tgreaves)
good question.
Old Jan 12, 2005 | 09:38 AM
DXK Eg's Avatar
Default Re: a question on rocker arms (ZoRG)
well, i was thinking to myself if i replace the camshaft why not buy so new valves too and so got a set of crower valves. But i used the oem valve springs. This was an *** to install...
si90rex
May 8, 2009 04:31 PM
crexer
33
Dec 29, 2006 10:04 PM
kpop
May 13, 2006 06:14 PM
luderollin
Mar 5, 2005 10:04 PM
asiangel
Sep 12, 2002 02:10 PM
