what problems did you run into when going turbo?
Old 01-05-2005, 08:09 AM
B16Civic93's Avatar
Default what problems did you run into when going turbo?
like it says, what problems did you run into when you went turbo? what problems have you had while you have been turbo? all of them, small, big whatever. let me know
Old 01-05-2005, 08:41 AM
Moderator
TheShodan's Avatar
Default Re: what problems did you run into when going turbo? (B16Civic93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 &raquo;</TD></TR><TR><TD CLASS="quote">like it says, what problems did you run into when you went turbo? what problems have you had while you have been turbo? all of them, small, big whatever. let me know</TD></TR></TABLE>
None.. if done correctly and thoroughly.
Old 01-05-2005, 08:46 AM
93turbo16's Avatar
lots of traction problems
But most problems seem to be oil line related. Make sure you get a good feed and good drain. More than I can say about my drain atleast, not very good but works for some unknown reason. And just make sure you have the right engine management onboard.
Old 01-05-2005, 08:59 AM
RyanEJ8's Avatar
I had some problems with downpipe fitment. Other than that install is very simple and if done correctly shouldn't have any problems.
Old 01-05-2005, 09:00 AM
hatchinprogress's Avatar
Default Re: what problems did you run into when going turbo? (RyanCivic2000)
i had problems on downpipe and intercooler fitment but not a prob after a lil cutting (car is an ef)
Old 01-05-2005, 09:20 AM
*Boostwerks*'s Avatar
Fitment for sure.
Anyone thats crammed a B series with a T4 into a CRX knows what I'm talking about. It looks like it fits until you have to get everything else in there...lol.
Old 01-05-2005, 09:46 AM
careawholelot's Avatar
Default Re: (Bryson)
oil return was a real bitch for me. the steel braided line and 2 -10an 45 degrees angles would not cooperate, fucked with it for like 8 hrs total. threw that **** across the yard then went and bought heater hose never leaked after that. i think its because where turbo sat and where the pan was taped thats what fucked me up.
Old 01-05-2005, 10:13 AM
greenGS's Avatar
I had the bolts holding my wastegate onto the manifold flange snap twice. Solved by using better bolts. Attention to detail is key
Old 01-05-2005, 10:27 AM
CivicEJ1's Avatar
Remember to put teflon on all your threaded things....I got oil leak since I forgot to put teflon on it....just drops not streaming
Old 01-05-2005, 11:01 AM
evosol's Avatar
Default Re: (careawholelot)
i have a serious problem now... i can't get enough boost! first it was 6lbs, 10lbs and now i want to try to boost 11-12lbs...
yeah pretty much like everyone... oil feed was a pain in the ***...
Robb
02-18-2007 05:35 PM
mike93boost
06-08-2006 02:40 PM
thastaniard
07-20-2004 10:43 AM
Scylla
03-19-2002 12:20 PM
ezark
08-01-2001 11:01 PM
Quick Reply: what problems did you run into when going turbo?
