d-series manifold
Old Jan 5, 2005 | 10:03 AM
wildcard69's Avatar
Default d-series manifold
hey whats up everyone, i am going to turbo my civic an was wondering if i can keep my a/c using the hf manifold with adaptor plate. thanks for any info
Old Jan 5, 2005 | 10:05 AM
beerbongskickass's Avatar
Default Re: d-series manifold (wildcard69)
No. You won't be able to keep A/C unless you make some funky *** adapter that moves the turbo away from the A/C ****...
menkio's Avatar
hmm, std/hf/etc are pretty small, i don't see why it would it the condesor with a turbo/adapter plate. Can you mock something up, find out how big everything is, and cut out some cardboard.
Old Jan 5, 2005 | 10:30 AM
RyanEJ8's Avatar
Default Re: d-series manifold (menkio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio &raquo;</TD></TR><TR><TD CLASS="quote">hmm, std/hf/etc are pretty small, i don't see why it would it the condesor with a turbo/adapter plate. Can you mock something up, find out how big everything is, and cut out some cardboard. </TD></TR></TABLE>
I think the way the manifold positions the turbo is the problem. Not the size of it.
Old Jan 5, 2005 | 11:03 AM
onefstek's Avatar
**** the Hf mani and make a turbo mani yourself. That way you can mock it up on the car and make it a/c compatiblle. 98ctr
Old Jan 5, 2005 | 11:39 AM
Default Re: (98ctr)
Exactly just make a log manifold.
Old Jan 5, 2005 | 02:19 PM
onefstek's Avatar
Default Re: (beerbongskickass)
log mani sould not cost you more then $100 to make. And you can set up the collector anywhere you want, so it will clear your A/C. 98ctr
Old Jan 5, 2005 | 03:42 PM
hurleyboarder21's Avatar
Default Re: (98ctr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ctr &raquo;</TD></TR><TR><TD CLASS="quote">log mani sould not cost you more then $100 to make. And you can set up the collector anywhere you want, so it will clear your A/C. 98ctr</TD></TR></TABLE>
this is what im gonna do .... well, at least attempt to
99hatchboy
Mar 6, 2005 11:35 AM
Maddhatcher
Sep 24, 2003 08:41 AM
dank9513
Jun 13, 2003 06:04 PM
974drgs
Dec 23, 2002 07:19 PM
89 CRX SI
Apr 8, 2002 09:15 PM
