Which BOV Would You Use?
Old Jan 5, 2005 | 11:01 AM
integlspwr2k's Avatar
Default Which BOV Would You Use?
I have a choice between three....
Greddy Type R
Greddy Type S
Blitz OG Horn Style...
Also which one sounds the loudest?
Old Jan 5, 2005 | 11:02 AM
Forgiveness's Avatar
Default Re: Which BOV Would You Use? (integlspwr2k)
turboxs RFL, hks ssqbov, apexi
Old Jan 5, 2005 | 11:03 AM
Default Re: Which BOV Would You Use? (Forgiveness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forgiveness &raquo;</TD></TR><TR><TD CLASS="quote">turboxs RFL, hks ssqbov, apexi </TD></TR></TABLE>
i perosonally dont like the build quality of the RFL,
I had a apexi one, but i didnt like it, and the for the HKS, didnt like how it sounds..
Old Jan 5, 2005 | 11:08 AM
Boostage's Avatar
greddy type r
Old Jan 5, 2005 | 11:09 AM
mike1114's Avatar
Default Re: Which BOV Would You Use? (Boostage)
get a duck call
Old Jan 5, 2005 | 11:33 AM
kevino002's Avatar
Default Re: Which BOV Would You Use? (mike1114)
greedy type rs
Old Jan 5, 2005 | 11:36 AM
Boosted2K's Avatar
Default Re: Which BOV Would You Use? (kevino002)
TYPE-S, gets the job done
Old Jan 5, 2005 | 11:37 AM
beerbongskickass's Avatar
Default Re: Which BOV Would You Use? (Boosted2K)
1g DSM...
Old Jan 5, 2005 | 12:09 PM
SpoolnG2's Avatar
Default Re: Which BOV Would You Use? (beerbongskickass)
over anything i'd get the tial....but if you had to pick from the 3 for performance i'd get the greddy type R
Old Jan 5, 2005 | 12:15 PM
igo4bmx's Avatar
Default Re: Which BOV Would You Use? (SpoolnG2)
RFL is the loudest
and i wouldn't get the type R because isn't it meant for high boost apps?
Old Jan 5, 2005 | 12:20 PM
FOrSfEd's Avatar
Default Re: Which BOV Would You Use? (igo4bmx)
I would also opt to get the Tial but from the three I would go witht he Greddy R, but be warned that it will not or usually will not work below 15 psi. IF you are running less than that daily then I would go with the greddy Type S
Old Jan 5, 2005 | 12:25 PM
Rod.'s Avatar
hks ss
out of those 3 i think the type s would be the loudest
Old Jan 5, 2005 | 12:50 PM
fast94ex's Avatar
Default Re: Which BOV Would You Use? (redturbocivic)
I love my rfl on 8.5psi. The best working valve imo is the tial, its probably better than any of the mentioned one but its just not loud enough for me . I would try out a greddy type-rs though.
Old Jan 5, 2005 | 01:16 PM
Default Re: Which BOV Would You Use? (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">I would also opt to get the Tial but from the three I would go witht he Greddy R, but be warned that it will not or usually will not work below 15 psi. IF you are running less than that daily then I would go with the greddy Type S</TD></TR></TABLE>
can't u swap put the spring from a type S and use it in a type R?
Old Jan 5, 2005 | 01:20 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">1g DSM... </TD></TR></TABLE>
Old Jan 5, 2005 | 01:52 PM
.::Lee::.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted2K &raquo;</TD></TR><TR><TD CLASS="quote">TYPE-S, gets the job done
OT, but that is one of the prettiest motors I have ever seen. CLEAN!!
Old Jan 5, 2005 | 01:55 PM
tgreaves's Avatar
Default Re: Which BOV Would You Use? (Ibiza)
I would get which ever one works..
Old Jan 5, 2005 | 02:00 PM
BoostedJeff's Avatar
i love the fluttering of my greddy type R
Old Jan 5, 2005 | 02:19 PM
onePOINTsix's Avatar
Default Re: Which BOV Would You Use? (BoostedJeff)
i had a RFL but sold it. it's too damn loud and starts to get anoying after a while. Probally going with HKS SSQ now
Old Jan 5, 2005 | 02:20 PM
MrBond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">i love the fluttering of my greddy type R</TD></TR></TABLE>
If it flutters you probably have the spring set too stiff!
My type R holds boost perfectly, also at part throttle, but gives just a whoosh when it opens...
Old Jan 5, 2005 | 02:22 PM
el arbi's Avatar
Default Re: Which BOV Would You Use? (MrBond)
Type S!
Old Jan 5, 2005 | 02:48 PM
PrettyLude's Avatar
the hks one does sound good, and performs well
Old Jan 5, 2005 | 02:50 PM
sir boostalot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrBond &raquo;</TD></TR><TR><TD CLASS="quote">
My type R holds boost perfectly, also at part throttle, but gives just a whoosh when it opens... </TD></TR></TABLE>
Not to get off topic, but I have TurboXS biggest BOV and am waiting to get it put on my turbo. I really want to know how you get that fluttering (rattlesnake noise)sound with the BOVs, is it the type of BOV you get, boost, spring or what?
Old Jan 5, 2005 | 03:28 PM
Dee's Avatar
Dee
Default Re: Which BOV Would You Use? (sir boostalot)
Greddy Type R
Most people do NOT setup their BOV's correctly! After allowing my BOV to sit in it's original box for a year, I disassembled it and added a moly based grease to the needed areas. When I was ready to adjust it properly, I loosened the spring until the turbo fluttered and then tightened until the fluttering stopped. I ran the normal Type R spring on my 8~11psi setup for a year without any problems. There are (3) different springs for the Type R [low boost (less than 10psi), normal spring (10psi-18psi) and high boost (above 18psi)] so if person is having problems it's because they didn't make the correct setting adjustments or are using the incorrect spring for their application.
Old Jan 5, 2005 | 03:54 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Which BOV Would You Use? (Dee)
hks ss.
