Greddy blue box work if using Missing link or check valves for MAP??
Old Jan 5, 2005 | 11:10 AM
Boosthead's Avatar
Default Greddy blue box work if using Missing link or check valves for MAP??
will the Greddy blue box work if using Missing link or check valves for MAP?? I'm afraid it wont. My understanding is that it adds fuel based on RPM and MAP, or is it just RPM?
Old Jan 5, 2005 | 11:30 AM
Forgiveness's Avatar
Default Re: Greddy blue box work if using Missing link or check valves for MAP?? (Boosthead)
i'm not sure...try the blue box w/out the missing link. if you get a CEL as soon as you boost, you need the missing link.
Old Jan 5, 2005 | 12:26 PM
turbopimp's Avatar
Blue box requires unaltered map signal to function properly. It already has a built in map signal clamp so the ecu doesn't go into limp mode when the map sensor sees positive pressure.
Old Jan 5, 2005 | 12:29 PM
Boosthead's Avatar
Default Re: Greddy blue box work if using Missing link or check valves for MAP?? (turbopimp)
anks, the problem is, despite my efforts to hook this up correctly, no matter what, I get a CEL and code 3 for MAP sensor.
Old Jan 5, 2005 | 02:21 PM
turbodohcsi's Avatar
try a different blue box, or just make sure you got the map wire running to the white wire, and the green wire actually running to the ecu.
Old Jan 5, 2005 | 07:40 PM
Boosthead's Avatar
Default Re: Greddy blue box work if using Missing link or check valves for MAP?? (turbodohcsi)
It looks like it is connected correctly. Unfortunately I dont have another blue box to try. Is it possible that my MAP sensor is bad and I didnt notice a problem because the car was NA? I need to pull out the multimeter and check voltage at the sensor.
xiLLtegRax
Apr 28, 2008 08:19 AM
supermac88
Apr 1, 2004 09:40 PM
B_1_8_hatch
Jul 22, 2003 10:04 PM
Sivik
Feb 4, 2003 01:42 PM
Blackcivic1
Nov 4, 2002 04:03 AM
