Turbo skunk 2 cams?
Turbo skunk 2 cams?
Anyone here running a b series turbo motor with skunk 2 stage 2 cams? I just wanted to know the increase in hp or the butt dyno.I have a valve train that can handle the skunk 2 stage 2 but I either want to get the type r or skunk2's.I can get a set of r's for about $250 or the skunk2's for $400.Im not completely finished building my other motor but its setup to put out around 350 to 400 hp pump gas and 500hp race gas.
Re: Turbo skunk 2 cams? (Clone)
Not alot of people use the skunk 2 turbo cams (don't think they like them)... But I do know people had great success with the type R cams and imo I's go with them and save the $150 for something else for your set-up... You will probably make more power with them all the way to 9500rpm that I have seen.
Re: (slow90hatch)
I've been hearing the same about the skunk2's. I am going to keep my GS-R cams and get a set of cam gears to dial out the overlap. I've also read that the ITR cams could be a little aggressive for the street.
