internal/external wategate
Old Jan 3, 2005 | 05:53 PM
hatchedzex's Avatar
Default internal/external wategate
can i use a internally waste gated turbo on a externally gated manifold by taking off the internal gate... or is the exaust housing different. and also does anyone know of a manifold that will let me retain ac and ps on a single cam?
Old Jan 4, 2005 | 12:56 AM
turbopimp's Avatar
Default Re: internal/external wategate (hatchedzex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchedzex &raquo;</TD></TR><TR><TD CLASS="quote">can i use a internally waste gated turbo on a externally gated manifold by taking off the internal gate... or is the exaust housing different. and also does anyone know of a manifold that will let me retain ac and ps on a single cam?</TD></TR></TABLE>
Yes, you can use the internally gated turbo. Just remove the actuator canister and the flapper valve assembly. You'll need to get a downpipe flange that fits the exhaust housing. This will block off the flapper valve hole and allow a downpipe to be welded onto the flange. Almost every manifold available will allow you to keep AC and PS.
civic-r11
Jul 2, 2012 06:52 AM
92prelude23
May 14, 2008 05:27 AM
rohec04
Aug 6, 2007 03:49 PM
matto2413
May 22, 2006 06:00 AM
not7fifteen
Jun 14, 2002 01:58 PM
