which engine is the hf manifold from?
Old Jan 3, 2005 | 12:16 PM
Mr_Bojangles's Avatar
Default which engine is the hf manifold from?
I am ordering a gasket for my hf manifold, and I am not sure which engine it comes from. It is the hf manifold with an L on the #4 cyclinder.
please advise which engine code / year thank you...
(search engine is down)
Old Jan 3, 2005 | 12:30 PM
Jeffescortlx's Avatar
Default Re: which engine is the hf manifold from? (Mr_Bojangles)
From HMT, hope it helps:
d series manifolds
like the 'b' series, many companies make custom manifold for d series also, but d series guys have one other option also.......The "HF Manifold"
Everyone refers to it as the HF manifold but it came on other cars too. it came on the 88-91 CRX HF. it also came on a 88-91 Civic Std, they are hatchbacks with a 4 speed, vinal interior, and a black panel on the hatch that says 'Civic', (base model) Another car that has them is a 92-95 Civic CX/VX hatch. Newer cars have the precat style manifold like the HF manifolds. But they Pre-cat and manifold are 1 piece. You would have to chop off the cat inorder to use it. all you will need to use this as a turbo manifold is an 'adapter plate' which bolts to the manifold where the cat was and has a bolt pattern on the other side, the same as the turbo you choose to use, then you can just bolt the turbo to the manifold.
What the hell is a HF/STD/CX manifold, where can I get one and how do I know if it will fit my motor?
A.
The HF manifold came from 88-91 Honda CRX HF's, the STD manifold came from 88-91 Civic STD/DX baselines. How to tell them apart? The STD has larger ports and has an imprint of the #3 on runner #4. Check your local salvage yards, and check out the classifieds on our forum. This manifold will fit ANY D-series motor. This manifold was designed for a Pre-cat style design, No, a Turbo will not simply bolt directly to this manifold, and an adapter plate has to be made! (D16/D15 or ZC) engines will fit. Normal 4-2-1 or 4-1 manifolds will not work.
Old Jan 3, 2005 | 12:34 PM
Default Re: which engine is the hf manifold from? (Jeffescortlx)
Thanks for the info.
I however need to know which one of the couple of options has the L on the #4 cyclinder pipe.
I imagine the gaskets would be diffrent between the three styles. thanks
Old Jan 3, 2005 | 12:37 PM
I edited my first post to add more info, check it out again and see if that answers your question.
Old Jan 3, 2005 | 01:42 PM
L or 3 it's all the same my memory fails me once again...
Thank you very much for the info. Gasket has been ordered!
Old Jan 3, 2005 | 04:28 PM
actually it just happens I was right it is an L on the #4 runner.
so anyone know which year make model engine that manifold is off of?
Old Jan 3, 2005 | 10:21 PM
I would think this would almost be common knowledge, does anyone know?
Old Jan 4, 2005 | 12:16 AM
labatt50's Avatar
gasket is the same for all 3
Old Jan 4, 2005 | 07:55 AM
Default Re: which engine is the hf manifold from? (labatt50)
thank you for the reply,
it shows up on the computer as three differrent part #'s, but I'll just grab one and try it out
thanks again!
EKSedAndy
Mar 27, 2010 02:16 PM
b20vtechb
Mar 3, 2005 12:07 AM
hj
30
Dec 9, 2003 11:26 AM
