Where to mount pump/filter?
Old Jan 3, 2005 | 09:01 PM
vr6chris's Avatar
Default Where to mount pump/filter?
Here are two different areas where I was thinking of mounting my pump and filter. The first picture is of them in the car next to the fuel cell. The second picture is under the rear axle. Any reason why there would be any problems running it in car(with the pump being higher than the sump?) or above the rear axle? Thanks for the help.
Old Jan 3, 2005 | 10:33 PM
jDMJeRk's Avatar
Default Re: Where to mount pump/filter? (vr6chris)
w00t bump for a VW guy!
Old Jan 4, 2005 | 07:35 AM
vr6chris's Avatar
bump
Old Jan 4, 2005 | 07:42 AM
b18bturbo's Avatar
you want the flow of the fuel to have natural tendancy to flow downward use gravity in your favor. In your setup you could possibly run the pump dry if the fuel shifts or moves which can cause failure. If you run it at lost point it always will have some fuel fed by gravity.
Old Jan 4, 2005 | 07:45 AM
vr6chris's Avatar
Default Re: Where to mount pump/filter? (b18bturbo)
any ideas where to mount it then? there are no real flat spots under the car where I could mount the pump. Maybe one or two, and ill check em out.
PRO1
Sep 24, 2009 06:28 PM
vr6chris
Jan 4, 2005 09:17 AM
edgar306
Dec 29, 2004 08:43 PM
98AccordEX
Jul 2, 2004 06:51 PM
