basic turbo setup....will my exhaust be enough for it?
Old Jan 1, 2005 | 09:05 PM
a1320addict's Avatar
Default basic turbo setup....will my exhaust be enough for it?
i just got my xs-engineering turbo kit with apexi power fc takign care of em and a slew of other goodies rounding out the fuel system
it is a t28 t3 still not absolutley positive but i will be running 7 psi on the stock block until more money comes in
what im wondering is this
i havea hks hi power on the car right now....i believe its slightly smaller than a 2.5"....will this be ok to run? from what ive researched and talked with peopel about...backpressure is bad....but if there is none you can run into problems as well...
can someone set the answer straight and tell me if im good with the setup?
Old Jan 1, 2005 | 09:18 PM
W O T's Avatar
Default Re: basic turbo setup....will my exhaust be enough for it? (yehiknowrite)
2.25+ is fine for a low boost setup
Sure, bigger is better but youre fine
And you could have easily searched this topic
Old Jan 1, 2005 | 09:25 PM
beepy's Avatar
Default Re: basic turbo setup....will my exhaust be enough for it? (W O T)
Hell, I made boost just fine up to 7 PSI with my stock 1-3/4" exhaust. Spool improved quite a bit, though, when I finally increased it to 2.5".
Old Jan 2, 2005 | 08:01 AM
Default Re: basic turbo setup....will my exhaust be enough for it? (beepy)
i did search wide open throttle
Old Jan 2, 2005 | 09:04 AM
cnydc2's Avatar
That will work just fine for low boost. I have been running my Tanabe Racing Medallion on 7psi and have had no problems.
Old Jan 2, 2005 | 11:04 AM
Emshhh's Avatar
Default Re: basic turbo setup....will my exhaust be enough for it? (cnydc2)
i have same exhaust... i have had the same question.
you conside 10psi low boost?
Old Jan 2, 2005 | 01:16 PM
Default Re: basic turbo setup....will my exhaust be enough for it? (iGfrequency)
ive read articles where r&d people form like apexi and hks say 10 psi is low
in my mind...7 psi is low...10 psi is pushing it on a stock block
but i mean...i guess you could say 10 psi is low...considering there are people boosting 20+
Old Jan 2, 2005 | 05:13 PM
cnydc2's Avatar
I agree that w/ a stock block 10psi would be about the limit (at least for a GS-R). For somone with a built engine 10psi is still low. Talking exhaust 10psi is still low and your exhaust would be fine.
Old Jan 2, 2005 | 08:02 PM
cool bro...thanks a lot
ill post once its on!
Old Jan 2, 2005 | 08:44 PM
cnydc2's Avatar
TravisBiggie
Apr 23, 2013 08:31 PM
Spec R_GSR
Aug 22, 2006 09:05 AM
blackriceman
Apr 27, 2004 05:37 AM
xXx Justin xXx
Mar 20, 2003 09:23 PM
coupedup
Mar 19, 2003 09:42 PM
