ignition timing ...need help (to retard)
Old Jan 6, 2005 | 10:31 AM
hatchinprogress's Avatar
Default ignition timing ...need help (to retard)
hey everyone i pretty much know how to do my timing(it's obd-0) but i keep reading that you need to "jump" the conector wire (to send ecu into limp mode) but i want to know if thats safe......because 1) im now have turbo 2) the ecu is chipped(te) im worried about doing this because i have a f.i. chip please help! oh yeah i did search(9 pages) no luck
Old Jan 6, 2005 | 11:12 AM
93turbo16's Avatar
no you have to jump the connector to keep it from trying to reset the timing.
Old Jan 6, 2005 | 12:24 PM
Default Re: (93turbo16)
i jumped the connectors, now shouldnt a check engine light come on? (mine didnt)
Old Jan 6, 2005 | 01:09 PM
Default Re: (hatchinprogress)
ne1
Old Jan 6, 2005 | 01:13 PM
93turbo16's Avatar
yep the check engine light should come on. make sure you have a good connection. Are you running hondata?
Old Jan 6, 2005 | 01:21 PM
no turbo edit , but i been meesin with the connection, still no check light
Old Jan 7, 2005 | 09:44 AM
well now ive been told that the light shouldnt come(from the ef fourum) and i tried to fix the timing but the timing "jumps" around. so is there any other way to set the ignition timing??
Old Jan 7, 2005 | 09:52 AM
SOHC_MShue's Avatar
the whole point of jumping that connector is so that the timing doesn't jump around. Thats what i've heard anyways. It should make it so the timing doesn't increase with rpm.
Old Jan 7, 2005 | 10:06 AM
Default Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">the whole point of jumping that connector is so that the timing doesn't jump around. Thats what i've heard anyways. It should make it so the timing doesn't increase with rpm.</TD></TR></TABLE> thats the problem i jumped the connection and the timing still jumps....so is there any other way i can get the timing to stay still??
koa
May 24, 2018 12:05 AM
iponnet
Mar 16, 2011 05:33 PM
Wazup
Jul 15, 2009 10:13 AM
polishedturd
May 8, 2008 06:51 PM
doubleA
Apr 5, 2005 12:59 PM
