1g dsm bov??
Old Jan 2, 2005 | 04:57 PM
jcmcnugent's Avatar
Default 1g dsm bov??
Will a 1g dsm bov work well with the greddy kit for a d16 even though ill only be boosting 6psi? Would the greddy type s be better, also is the 1g bov loud because i dont want to draw a lot of attention to my engine?
Old Jan 2, 2005 | 06:23 PM
93turbo16's Avatar
haha, you are turboed and don't want attention. Good luck. Once someone finds out everyone will know. haha. But it should be fine as you can see many people run them.
Old Jan 2, 2005 | 06:36 PM
evilone's Avatar
Default Re: 1g dsm bov?? (jcmcnugent)
the 1g bovs work well, and are a lot cheaper than the greddy
Old Jan 2, 2005 | 07:59 PM
Blackack26's Avatar
Default Re: 1g dsm bov?? (prostock)
Mine works great
Old Jan 2, 2005 | 08:11 PM
evosol's Avatar
Default Re: 1g dsm bov?? (Blackack26)
I also run a 1g dsm bov and it works pretty good @10lbs. Its not too loud, just perfect. A tip if you decide to go with one... what i ended up doing since i didn't want to have to wait on ordering a BOV flange, i just dremeled the weld inside the stock dsm elbow, popped off the flange and welded that mug on to some 1.5" tube and then on to the charge pipe.
people say that your not supposed to weld cast onto mild but it should be fine since its not supporting any weight.
Old Jan 2, 2005 | 08:32 PM
Cee_mon's Avatar
Default Re: 1g dsm bov?? (evosol)
1st gen DSM @7psi on d16z6
http://www.we-todd-did-racing....DE%3D
Old Jan 2, 2005 | 08:45 PM
thelate1's Avatar
haha...... i tried that too. i ended up going through like 20 cut off wheels. needless to say it was unsalvagable
i'm going to be running one also though, i've read good things about them for low buck boost.
good luck.
Old Jan 2, 2005 | 09:45 PM
blackeg's Avatar
Default Re: 1g dsm bov?? (thelate1)
my dsm 1g was nice on my single cam turbo at 6 psi. i have a link to a vid in my garage in my sig if you want to see it
turbodcivic510
Mar 25, 2007 12:39 PM
Mario.
Jul 13, 2005 03:17 PM
Pnoyej6
May 23, 2005 06:17 PM
boostincoupe
Jun 26, 2003 03:07 PM
boostincoupe
Jun 19, 2003 12:20 PM
