finished the d15b7 setup, lovin it
Old Jan 3, 2005 | 02:24 PM
Scean's Avatar
Default finished the d15b7 setup, lovin it
i finished up my d15b7 turbo setup over my xmas break, i freakin love it, pulls nice, i know its nothing crazy but a great learning project and made my car more fun on the street.
One kinda technical question tho, im runnin uberdata and im running a nice conservative basemap for now, i know i know i need a wideband tune but i jsut cant afford one, im only boosting 5-6 psi, (my autometer reads 8 but it also read 1.5 when its off, p.o.s.) and im running quite rich, w/ some smoke at idle and start up, and an occational bog in first gear, my question is it safe to pull a little fuel? and if i dont then will the black deposit from runnin rich that collects in the exhast get on my turbine wheels and end up damaging them? and info would be great and i heart boost!!
Old Jan 3, 2005 | 03:37 PM
Slammd Sol's Avatar
get a wideband on it.. that'll tell ya if its safe to pull some fuel.
Old Jan 3, 2005 | 03:40 PM
SOHC_MShue's Avatar
Default Re: finished the d15b7 setup, lovin it (blackcivic95)
save up some money and get a wideband. I know its expensive, but its well worth it. Have you had anybody check out your basemap yet?
Old Jan 4, 2005 | 05:30 PM
Scean's Avatar
Default Re: finished the d15b7 setup, lovin it (SOHC_MShue)
yea thats definatly next on my list but it may be a lil while before i can get one, for now tho, like i asked will the deposits from it running rich gather on my turbo's fins and cause any damage? and also i have a cel for my map sensor that i cant seem to get rid off, any ideas on that either?
Old Jan 4, 2005 | 05:37 PM
93turbo16's Avatar
no it should be ok. But you can pull some fuel down low in the map. what version are you using? Please tell me 1.66
Old Jan 4, 2005 | 05:40 PM
Scean's Avatar
Default Re: (93turbo16)
yea its 1.66
Old Jan 4, 2005 | 05:57 PM
Scean's Avatar
Default Re: (blackcivic95)
how much should i pull out? 5% 10% more? it does smoke some at idle
Old Jan 4, 2005 | 06:01 PM
Luke J's Avatar
what kinda fuel pressure are you running?
Old Jan 4, 2005 | 06:04 PM
Scean's Avatar
Default Re: (Lucky925l)
stock, only fuel modification is dsm 450cc injectors
Old Jan 4, 2005 | 06:28 PM
93turbo16's Avatar
i forget what I pulled out on my car. I did pull some out because it was noticible rich at idle, and I did this without a wideband.
Old Jan 4, 2005 | 07:14 PM
Scean's Avatar
yea ill just pull it out little by little and get a nicer idle
Old Jan 5, 2005 | 02:35 PM
Scean's Avatar
what about my map sensor code, cant seem to get rid of that, and i have the map sensor settings in uberdata set to stock. Also my car backfires everynow and then, more so when im kinda cursin in the lower rpm's, what exactly causes a backfire and what can i do to fix this as well?
Old Jan 6, 2005 | 10:09 AM
Scean's Avatar
bump
Old Jan 6, 2005 | 10:11 AM
93turbo16's Avatar
What code are you throwing.
Old Jan 6, 2005 | 10:13 AM
Scean's Avatar
code 3
Old Jan 6, 2005 | 10:22 AM
Burke's Avatar
Banned
you may have chipped you ecu not quite right if you are getting a map code. happened to me before.
Old Jan 7, 2005 | 10:33 PM
Tad's Avatar
Tad
sweet man!!
once you get the bugs worked up crank it up!
what injectors are you running?
I say crank it up to 8 or 9,
I mean seriously, the d15b7 block shouldn't be any weaker than any other d block.. its just that the head doesn't flow like a z6 head does, which is the big reason it's so much weaker imo.
So now that you're boosted.. prettymuch I think you could put down 180whp RELIABLY with that motor.
I for one would LLOOOVE to see it too!
post some pics!
Old Jan 9, 2005 | 05:25 PM
Scean's Avatar
Default Re: (Tad)
I thought the b7 head flowed better than most d-series head?? and the weakness in in the rods, really thin, in time i probobally will turn it up to about 7-8 but i need a better tune first
Old Jan 12, 2005 | 10:10 AM
Scean's Avatar
Default Re: (Scean)
any other ideas on the code 3 rather than a bad chip install cuz ive been over that a few times now an am pretty sure its good
sleepgsr
Sep 14, 2009 01:33 PM
LSEGHATCH
Mar 20, 2007 06:06 AM
99TurboFerio
Apr 7, 2005 04:37 PM
B17aTrbo
Oct 23, 2001 03:55 PM
