D16Z6 181.2/172.0 T25 8-9psi
95 EX with D16Z6
edelbrock SOHC manifold... custom adapter plate for the dsm t25, dsm sidemount, dsm bov, dsm o2 housing, 2.5" downpipe, 2.25" catback... but there's no cat
dsm 450's, stock pump, stock regulator, 2" ic piping, arp studs, new oem headgasket and t-belt (160,000 miles lol)
boost was fluctuating between 8-9psi.. a/f low 12's into mid 11's on top, prolly could've made a ton more but seeing as this is a daily / winter beater with 160,000 i didnt want to push it too hard.
http://www.maxpowertuning.com/mikegee.html
Baseline On a Dynojet (before turbo)
After turbo on dyno dynamics (181.8/172.0)
Re: D16Z6 181.2/172.0 T25 8-9psi (Toda Party)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">Is this a non intercooled setup.?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda Party »</TD></TR><TR><TD CLASS="quote">...dsm sidemount</TD></TR></TABLE>
His IC sits right infront of the turbo (where the A/C wouldve been).
Re: D16Z6 181.2/172.0 T25 8-9psi (tegunderpressure)
guys its not my car its my friend's who wanted a peppy daily driver so he gave me the car to do with as i pleased, i told him what to buy and we installed/tuned it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">Interesting setup.
That 2.25 exhaust is killing you, the IC piping could be larger also.
But not bad. Whats fuel management?</TD></TR></TABLE>
prolly coudda gone bigger, but he already had a 2.25" muffler/axle back he wanted to keep, plus its just a T25 on low boost, we're not shooting for record breaking numbers or anything, 2.5" downpipe reduced to a 2.25" "catback" w/ no cat was good enuff for the situation.
ic piping is 2"... its big enuff for the situation
we're using uberdata 1.6 on it...
personally i didnt think we'd break 170 whp
Re: D16Z6 181.2/172.0 T25 8-9psi (phresh_5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phresh_5 »</TD></TR><TR><TD CLASS="quote">Nice work
Check out mine:
https://honda-tech.com/zero...age=1</TD></TR></TABLE>
nice, i sorta wish i could've turned the boost up but oh welll
holla @ 160,000 mile Dseries turbo ninjas
his clutch is slipping BAD haha
Check out mine:
1.7 is out, just FYI.
his clutch is slipping BAD haha</TD></TR></TABLE>
Poor guy has the power but can't fully use it
i think the dyno session put it over
it was fine when i was street tuning/driving around on the basemap...
after the dyno i was scared shitless the clutch would blow (i had to drive it 400 miles home afterwards)
Re: D16Z6 181.2/172.0 T25 8-9psi (sleeprhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeprhatch »</TD></TR><TR><TD CLASS="quote">d series powa </TD></TR></TABLE>
Guest
Posts: n/a
Re: D16Z6 181.2/172.0 T25 8-9psi (EJ1 wilcox)
Isn't the kinda close or the charge piping in a bad place like smack dab right over the manifold? Either way nice job on your friends setup. Why wouldn't he just put a t3 on it since the manifold was setup for that?
Re: D16Z6 181.2/172.0 T25 8-9psi (egizzle6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 »</TD></TR><TR><TD CLASS="quote">Isn't the kinda close or the charge piping in a bad place like smack dab right over the manifold? Either way nice job on your friends setup. Why wouldn't he just put a t3 on it since the manifold was setup for that?</TD></TR></TABLE>
that's why we made the heat shield. it gets warm to the touch after a long drive, not much hotter than that. we really only put it there so it didnt melt the rubber coupler.
the edelbrock manifold is flanged for a T25/8...
http://www.edelbrock.com/autom....html
i found out the hard way after i picked up a nissan t28 and both the manifold and turbo were studded lol, so thats why we ended up using the t25 w/ the plate..
