GE vaccum manifold problems
Old Jan 1, 2005 | 01:33 PM
DRAGLS's Avatar
Default GE vaccum manifold problems
Modified by DRAGLS at 7:14 PM 1/5/2007
Old Jan 1, 2005 | 01:38 PM
underpressure02's Avatar
Default Re: GE vaccum manifold problems (DRAGLS)
this is a really dumb question but did you drill the ports in the vaccum manifold?
Old Jan 1, 2005 | 01:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">your telling me that they don't come pre-drilled</TD></TR></TABLE>
Not sure if you are being serious or not but just incase your are serious no you have to drill them. That way you don't need to block off all the extra ports that you don't use.
Old Jan 1, 2005 | 01:54 PM
integlspwr2k's Avatar
they do not come predrilled for if they did, you would need to plug all the ones your not using and i presume you didnt plug up the ones you werent using..
Old Jan 1, 2005 | 01:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">I installed it in a hurry didn't really look at the manifold inside I am a dumdass
I thought it came drilled I bought plugs for the ones I didn't use
Thanks</TD></TR></TABLE>
No problem just wasn't sure if you were being serious when you said it.
Old Jan 1, 2005 | 02:00 PM
Frozen E's Avatar
H-T White Ops
Hahahaha. Funny ****.
Old Jan 1, 2005 | 02:06 PM
alpha's Avatar
Dont worry about it. Mistakes will happen. Just be happy you caught this one early on
Old Jan 1, 2005 | 02:10 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">Alright guys jokes over! Manifold is black didn't catch it... </TD></TR></TABLE>
Don't worry about it. I tapped my brake booster AFTER the chack valve the first time. Check valves on the EM1 is kinda built into the hose and not obvious like on the EG's.
Old Jan 1, 2005 | 02:58 PM
evosol's Avatar
Default Re: GE vaccum manifold problems (IslandSi)
oh damn... good catch!
Old Nov 10, 2005 | 06:03 PM
R6E6I6D's Avatar
Default Re: GE vaccum manifold problems (evosol)
wahts tapping it after the check valve do??
mines like this...... (vaccum manifold) ===Tee== (checkvalve)=== (brakebooster)
.................................................. ...........(I manifold)
Old Nov 10, 2005 | 08:06 PM
T4eg's Avatar
i did the same thing on the 1st one I installed also....dont feel bad
spoolin turbo s
Dec 2, 2007 05:30 AM
b00stedbyFastrax
Jun 5, 2006 02:42 PM
civicdust
Nov 1, 2004 02:52 PM
donkiman
Oct 8, 2004 08:57 AM
Universal Magnetic
May 27, 2004 04:09 AM
