Turbo question?
Old Jan 4, 2005 | 04:40 PM
99_dc2's Avatar
Default Turbo question?
Hi.. i just bought a turbo kit and i had a few questions.. i have a drag 3 turbo kit with a with revhard manifold.. i was woundering if i can run my car for a few months untuned until i can get hondata.. and also someone told me to get a cometic head gasket about 3mm to lower compression.. do you guys think its safe? thanks in advance
Old Jan 4, 2005 | 05:49 PM
Scean's Avatar
Default Re: Turbo question? (99_dc2)
no you cant just throw the turbo in there w/out some kinda fuel modifying system, i dunno if the kit comes with something but u need at least an fmu and keep the boost low, and i dunno about the headgasket but replacing yours before you turbo is a good idea, and you might as well install some ARP headstuds while the head is off.
Old Jan 4, 2005 | 06:15 PM
Makdaddynuge's Avatar
yeah, maybe an FMU at low low boost would be ok. But get hondata asap.
Old Jan 4, 2005 | 06:34 PM
99_dc2's Avatar
Default Re: Turbo question? (Makdaddynuge)
yea the kit comes with a fmu.. does this mean i dont need injectors yet?
Old Jan 4, 2005 | 06:49 PM
kabaroo's Avatar
yea i would run fmu on super low boost, or just wait to install it all at once.
i plan on using fmu or a greddy bluebox to get me 150 miles to get hondata tuned
Old Jan 4, 2005 | 06:58 PM
99_dc2's Avatar
Default Re: Turbo question? (kabaroo)
okay thanks guys.. a few more questions.. will the 3mm headgasket be fine? and what kind of fuel pump should i get?
Old Jan 4, 2005 | 10:54 PM
PrettyLude's Avatar
if you want to get a fuel pump, get a walboro from lightningmotorsports. for that low of boost, i wouldn't even put the 3mm headgasket in
Old Jan 5, 2005 | 12:40 AM
BoOsTeD C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">okay thanks guys.. a few more questions.. will the 3mm headgasket be fine? and what kind of fuel pump should i get?</TD></TR></TABLE>
I have a some buddies with those headgaskets and they told me biggest mistake they made but those are just my buddies...As for fuel setup i would run saturated rc 550's and walbro 255hp intank with that hondata ems you should make some nice numbers but all depends on who is your tuner.
Old Jan 11, 2005 | 11:50 PM
rothjpkb's Avatar
if you need i shure some one in your town can hack your ECU and give
you the fuel and timing you need it not that hard
LU
Feb 9, 2007 10:04 AM
WorkedDelSol
Jun 28, 2006 10:22 AM
97dc2
May 6, 2005 06:07 PM
StolenTeg
Jun 1, 2004 12:10 PM
gsracer170
Mar 15, 2003 01:17 AM
