lil weekend project dyno! 9 psi
Old 01-04-2005, 05:10 PM
racerboyb18c1's Avatar
Default lil weekend project dyno! 9 psi
list of mods - 9:1 je pistons, eagle rods, 97 itr head with b16a cams , crap mild steel manifold , open dp, tial 38mm wg, 2 inch intercooler piping before IC 2.75 after , core size 22inch tall 2.5 inch thick 38inch wide (lots of bumper mods)dont know who made it looks homemade everything built in less than 24 hours just some **** we through together to put in a friends 92 hb oh yah the turbo is a garret t3t4 .60 .63 witha stage 3 compressor wheel made full boost by 3200 pulls hard all the way to 8500rpm i say its the cams
Old 01-04-2005, 05:11 PM
93turbo16's Avatar
not bad, looks like it needs some tuning though. Pics of the setup?
Old 01-04-2005, 05:14 PM
Default Re: (93turbo16)
i would post pics of the setup but the guy i built it for after i got it all done ditched out on me the money he owes me but just thought id share the dyno , it was tuned with uberdata < curious to why you would say it looks like it needs tunning though?
Old 01-04-2005, 05:21 PM
93turbo16's Avatar
Just noticing the nice flat portion of the graph, but that may be because of turbo trying to spool? That sucks about the guy ditching out, that would make me angry. Impressive none the less.
Old 01-04-2005, 05:25 PM
loseneon's Avatar
add more timing from 4000-5000rpm in the low cam. monitor knock via some knock detecting device(at minimal have someone sitting with their ear over the engine and have them hear knock) when audible knock comes, retard the timing back 1.5-2*. then graph your low cam only(vtec disabled) and then graph when you set vtec at 3000rpm. the place it intersects is your new vtec point
In short, your midrange sucks becuase your vtec engagement is high and your low cam doesnt have enough timing.
Old 01-04-2005, 05:47 PM
b16sedan's Avatar
Default Re: lil weekend project dyno! 9 psi (racerboyb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerboyb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">pulls hard all the way to 8500rpm i say its the cams </TD></TR></TABLE>
How do you figure that the smallest B-series VTEC cams made the car pull to 8500? It would have pulled harder and longer with GSR or ITR cams.
Old 01-04-2005, 06:22 PM
TurboJesse
Guest
Posts: n/a
Default Re: lil weekend project dyno! 9 psi (b16coupe)
nice...alot of uberdata data cars reppin lately
Old 01-04-2005, 09:29 PM
Default Re: lil weekend project dyno! 9 psi (Mpir3)
dr charles and i agreed that b16a cams are the best for turbo setups cus of the low over lap and i think since lisa kubo ran 9s with em i think it will work just fine
Old 01-04-2005, 09:41 PM
SpdFrk's Avatar
Nice number for 9psi
Was this a b16 or b18? and whats the bore size?
Old 01-04-2005, 09:43 PM
DefiantGSR's Avatar
350whp on a crap manifold and fairly normal sized turbo? all on 9psi? oh my!
Old 01-04-2005, 09:46 PM
*Boostwerks*'s Avatar
Wow...if I were you, I would move that vtec point way lower.
say about 4200.
Old 01-04-2005, 09:47 PM
DefiantGSR's Avatar
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Wow...if I were you, I would move that vtec point way lower.
say about 4200. </TD></TR></TABLE>
for reals! I wonder how much better his midrange will loook!
Old 01-04-2005, 09:52 PM
Default Re: (DefiantGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR &raquo;</TD></TR><TR><TD CLASS="quote">
for reals! I wonder how much better his midrange will loook!</TD></TR></TABLE>
Flat...hehe.
Old 01-04-2005, 09:57 PM
id love to make some more tunning efforts but thats all the time we had and all the customer wanted and yes we had a better low end map but we lost the map with alot of tunning and had to have a new map made in a short time , also the costomer jacked me for alot of money and work so i will no longer see what it would of made oh well ill bring somthing else to the table when i get er done
Old 01-04-2005, 10:32 PM
quik sol's Avatar
wow....nice numbers
Old 01-04-2005, 10:59 PM
evosol's Avatar
Default Re: (quik sol)
nice job representin Washington! That sucks that guy bailed on you...
Old 01-04-2005, 11:52 PM
H.A.R.T B18C1EG6's Avatar
Default Re: (evosol)
nice numbers on 9psi
Old 01-05-2005, 12:46 AM
Ls1 FD3s's Avatar
Default Re: (H.A.R.T B18C1EG6)
dont think i have ever seen numbers like that on only 9 Psi before...
Old 01-05-2005, 02:44 AM
TSPeed Factory
AzntaggeR's Avatar
Default Re: (Ls1 FD3s)
nice #s....i hope to hit those numbers with my b18c1.
Old 01-05-2005, 02:45 AM
TSPeed Factory
AzntaggeR's Avatar
Default Re: (AzntaggeR)
ohhhh i just noticed that was at intec racing. thats where i got my car dyno'd as well. so who tuned it for you?
Old 01-05-2005, 05:59 AM
VTC_CiViC's Avatar
Pretty crazy power out of that turbo at only 9psi
What was the A/F in boost?
Old 01-05-2005, 06:20 AM
HXMan's Avatar
That chart is crazy...I don't understand.
Old 01-05-2005, 07:11 AM
Triscuit's Avatar
Default Re: lil weekend project dyno! 9 psi (HXMan)
Very nice numbers..............
Old 01-05-2005, 07:52 AM
m R g S r's Avatar
gsr or type r short block?
Old 01-05-2005, 09:31 PM
Default Re: lil weekend project dyno! 9 psi (m R g S r)
listed above the setup but its a ls block b18a! thanks you guys me and my friends use uberdata
Quick Reply: lil weekend project dyno! 9 psi
