CYP sensor, car is bucking in low rpms. How do I solve this problem
It got a little worst now. The car bucks sometimes when I am taking off then goes away. I changed out my worn out rotor. The CEL didnt come on when i started it like it does always. Now it coming back on when starting the car. I have a distributor king dizzy. How do I get rid of this code??
Re: (gaydm.accord)
cel9....... no1 cylinder position cylinder. Misifiring around 3grand and sometimes even lower when starting to drive. It is weird sometimes it will do it and sometimes it will not. It has a mind of its own
Re: (redturbocivic)
you gotta replace the distributor, call allen at honda heaven and get an oem one. It's possible that it could be something in the wiring, but it's more likely to be that junk distributor.
Re: (redturbocivic)
Is this a Hondata tuned car? I heard and have have experienced that when running Hondata say you are cruising on the freeway (not really accelerating but not letting off of the gas either, just keeping constant pressure on the pedal to maintain a speed) that when you press the pedal to accelerate the car will buck slightly before picking up normal driving. This is especially annoying when slowly cruising in 1st gear. I hope this make sense...
Re: (Kwuaymaikrup)
If it's giving you that code, then it's either the sensor inside the distributor, or the wiring to that sensor. Honda Heaven's number - 871-274-7288
