JG intake manifold worth ithe cost on a B16A?
Old Jan 4, 2005 | 10:59 AM
Importracer_001's Avatar
Default JG intake manifold worth ithe cost on a B16A?
Is a JG intake manifold worth it or is it just a hype?
I've got a stock B16A1 intake manifold right now holding about 16 psi boost.
DOes this Jg manifold have great power gains or should I keep my stock intake manifold and invest into something else?
Like a 3" downpipe instead of a 2,5" downpipe that I have right now?
Old Jan 4, 2005 | 11:25 AM
Marauder's Avatar
Default Re: JG intake manifold worth ithe cost on a B16A? (Importracer_001)
How much power are you making? What are you revving to?
Old Jan 4, 2005 | 11:32 AM
Default Re: JG intake manifold worth ithe cost on a B16A? (Marauder)
I dont have any access to a dyno yet
My revlimit is set @ 8400rpm
I don't know if this helps but my best time @ the track is 12.42 @ 118mph on BFG Drag radials.
Old Jan 4, 2005 | 11:42 AM
jDMJeRk's Avatar
I have the revhard manifold which is the SAME thing but this is how I look at it logically...
How does a turbo make a car go faster? It FORCES air into the manifold thus it making more power. What if you opened everything up that the psi is traveling to, IE larger dp's larger charge pipes, bigger intake manifold, port and polish, and even port matching helps.
The main idea is the faster you get the air in and out the more power you can make.
But if your not making high power to begin with, the manifold could be an over kill. Id say 16psi is enough boost to where if you opened up everything the boost goes through you could make a bit more power.
hth!
Old Jan 4, 2005 | 12:25 PM
GT30LSVTEC's Avatar
I think its worth it to buy the JG manifold, especially if you are boosting on it. I'm currently runinng a skunk 2, but my roomates JG seems to be making a much larger difference in power. It's also good to use if you plan to make more upgrades to you engine.
Old Jan 4, 2005 | 03:50 PM
pimpintyperintegra's Avatar
I would say it is worth the cost...they are really not expensive compared to other manifolds.
The Edelbrock manifold is the best for the money, I think.
The AIR or a custom made one would be better, but much more expensive...and overkill on your set-up.
Old Jan 10, 2005 | 05:14 AM
Default Re: JG intake manifold worth ithe cost on a B16A? (pimpintyperintegra)
thanks guys.
I bought the manifold, have to get a hondata intake manifold gasket so I can install it.
egycasper
Welding / Fabrication
Jul 19, 2019 04:16 PM
DelSolMarine
Mar 7, 2006 05:40 PM
Home Wrecker
Feb 23, 2006 10:13 AM
YellowR2000x2
Feb 3, 2003 04:17 PM
