fot those with electronic boost controllers...
Old Jan 1, 2005 | 04:29 PM
mildly.interesting's Avatar
Default fot those with electronic boost controllers...
maybe it's just with the Profec Spec B, but it makes my turbo spool about 600 rpm sooner than just the wastegate spring.
Do you leave your EBC on, and on the lowest setting, or do you cut it off and let it boost on the WG spring?
This is on a daily basis, not when you're at the track, just when you're riding around.
my wastegate spring is 9lbs, and my low boost setting is 14 lbs, high boost is 20 lbs...
Old Jan 1, 2005 | 05:36 PM
adseguy's Avatar
Default Re: fot those with electronic boost controllers... (mildly interesting)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mildly interesting &raquo;</TD></TR><TR><TD CLASS="quote">maybe it's just with the Profec Spec B, but it makes my turbo spool about 600 rpm sooner than just the wastegate spring.
That is the advantage of having an EBC. Since normally on a just a spring, the WG valve will start to open before full boost is reached letting out gas that could have been used to spool the turbo. the EBC acts as an on/off switch instead of the slow gradual opening of the vavle if it were just on the spring.
Modified by adseguy at 8:52 PM 1/1/2005
adamsjm5
Sep 15, 2005 06:18 PM
turbo95eg6
Jun 12, 2005 07:46 PM
5l-eater
Oct 20, 2004 03:26 PM
shingles
Jan 24, 2003 01:58 AM
wonny
May 30, 2002 03:18 PM
