Help please,,,b18b weired engine sound
Old Jan 2, 2005 | 07:29 PM
alghafat424's Avatar
Default Help please,,,b18b weired engine sound
my car was driving fine this morning, just drove it and noticed a weired sound(like knocking ) and some smoke from the breather. could it be ringland???,,,,th car was tuned by a professional,,,,,and I hope it is not the ring. appreciate your help
Old Jan 2, 2005 | 07:38 PM
chingo's Avatar
Default Re: Help please,,,b18b weired engine sound (alghafat424)
rings or ring land if its smoking out the breather, and i would stop driving it dont want any of those small pieces going into the turbo.
Old Jan 2, 2005 | 08:24 PM
Default Re: Help please,,,b18b weired engine sound (chingo)
based on what I read, white somke from the breather==> ring or ring land
but,,,,,how about the knocking sound????
how much am I going to pay for parts and labor if it is ring or ring land?
Old Jan 2, 2005 | 08:34 PM
underpressure02's Avatar
did you check your oil? Is it low? Is there anything in the oil? Metal antifreeze? Start with the basics
quicksol95's Avatar
alot the rings are about 100 bucks
but the labor will get you
b/c of having to pull the whole motor apart
Old Jan 2, 2005 | 08:45 PM
Default Re: Help please,,,b18b weired engine sound (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">did you check your oil? Is it low? Is there anything in the oil? Metal antifreeze? Start with the basics</TD></TR></TABLE>
thanks man, just checked the oil, there was no oil at all
hopefully, I didn't break anything
Old Jan 2, 2005 | 08:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alghafat424 &raquo;</TD></TR><TR><TD CLASS="quote">
hopefully, I didn't break anything</TD></TR></TABLE>
Okay when you say no oil do you mean none on the dipstick? Put a quart of oil in see if it shows up on the dip stick if not then put another one in and so on and so forth. Did you boost hard on it with no oil? Is something leaking that you would have lost your oil?
Do you have an oil pressure guage?
Old Jan 2, 2005 | 08:56 PM
yup, none on the dipstick,,,,
I didn't hit boost after hearing the sound
thanks a lot underpressure02
Old Jan 2, 2005 | 09:00 PM
check that and go from there. Hopefully when you put some oil in the knocking will go away. But it must be pretty low if your knocking. On my old car that was stolen I did not check the oil for a while and was 2 quarts low and the motor did not knock. Put some oil in it and it was good to go.
Also try and find out why you are loosing oil. Maybe you are burning it, maybe you have a leak. If you have a leak or if something came loose try and figure out where.
B18C5_VTEC
Jun 11, 2007 07:36 PM
Jorsher
Sep 7, 2006 06:05 PM
kihun_cha
Jan 2, 2006 07:45 AM
turbolsintegra26
Aug 18, 2004 09:13 PM
chinhead1228
Jun 17, 2003 09:38 PM
