boost vs boost/vac gauge
Old Dec 31, 2004 | 01:21 PM
2 point 0's Avatar
Default boost vs boost/vac gauge
which one do u guys have? is the boost/vac necessary? or will i be fine with just boost?
Old Dec 31, 2004 | 01:45 PM
MooreBoost's Avatar
Default Re: boost vs boost/vac gauge (2 point 0)
I have boost/vac. I suppose it might be beneficial in figuring out if you have a vac leak or not.
Old Dec 31, 2004 | 01:46 PM
2 point 0's Avatar
Default Re: boost vs boost/vac gauge (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">I have boost/vac. I suppose it might be beneficial in figuring out if you have a vac leak or not.</TD></TR></TABLE>
good point. how much harder is it to install the boost/vac compared to just boost? is it just a matter or hooking up a vac line?
Old Dec 31, 2004 | 01:49 PM
MooreBoost's Avatar
Vac lines and boost lines are the same thing (assuming you tap after the TB). Thus, the install is exactly the same.
Old Dec 31, 2004 | 01:50 PM
dctoast's Avatar
just hook up a vac line.. and like he said its good for seeing if ya have vac leak..
Old Dec 31, 2004 | 02:00 PM
evosol's Avatar
Default Re: boost vs boost/vac gauge (dctoast)
ive got just boost... its kinda annoying seeing that needle go everywhere, 20" vac to 10psi. but thats just me
Old Dec 31, 2004 | 03:09 PM
Tchleung's Avatar
boost/vac gauge is good for self street tuning as you can see what RPM you are at and where you are in vac for part throttle tuning.
turbonitrousgsr
Oct 6, 2003 06:54 AM
Obie
Sep 11, 2003 05:08 PM
cajnatc
Jun 13, 2003 04:18 AM
Etylorcen
Jun 24, 2002 11:11 AM
b18tdelsol
May 18, 2002 11:46 AM
