Decisions decisions...
Old Jan 6, 2005 | 01:45 PM
swlabhot's Avatar
Default Decisions decisions...
My B18C6 in my ITR has one of the stock sleeves cracked all the way through and so it needs new sleeves. The JEs pistons and Eagle Rods survived so I plan to use these again. Should I:
a) Resleeve the ITR block with Darton/Benson etc.. sleeves and use the JEs and Eagles back in after it has been resleeved, OR
b) Drop in a used bone stock B18C1 with stock sleeves and use the JEs and Eagles from my blown block. Re-build the ITR block with stock sleeves or the like and sell it off as a long block at a later stage.
Funds are very short at the mo as I'm moving house and I've got my eye on an NSX as well, hence my option for b) as a used B18C6 is fairly cheap. I'm only planning on getting about 400whp+ out of it once its back on the road so I think stock sleeves should be OK.
Suggestions?
Old Jan 6, 2005 | 01:47 PM
DefiantGSR's Avatar
Default Re: Decisions decisions... (swlabhot)
A
Old Jan 6, 2005 | 02:36 PM
PrettyLude's Avatar
depending on how bad the crack is, benson might be able to fix it
Old Jan 6, 2005 | 02:55 PM
swlabhot's Avatar
Default Re: (PrettyLude)
I seriously doubt it
And besides I'm not on the same side of the pond
Old Jan 6, 2005 | 03:11 PM
PrettyLude's Avatar
pm earl or vince, and let them take a look at it
Old Jan 6, 2005 | 03:37 PM
Rod.'s Avatar
dayum....let the sleeving guys look at that
Old Jan 6, 2005 | 04:07 PM
s2kdre's Avatar
Default Re: (redturbocivic)
vtecs are over rated get an ls for 300 and use your head.
Old Jan 6, 2005 | 09:57 PM
earl's Avatar
Default Re: (swlabhot)
This block is fixable with Benson sleeves. Some custom welding will need to be done by Benson which will run an extra $100 above the sleeving cost. New sleeves with the final bore and hone runs $950 plus $50 on return shipping. So in your case, with welding, you are looking at $1100 to fix. No align bore would be necessary and the welding will make the block as good as new.
Old Jan 7, 2005 | 09:13 AM
swlabhot's Avatar
Default Re: (earl)
Earl u got PM
GT500FTW
May 16, 2013 10:27 AM
Boostn B20
Aug 20, 2008 03:28 PM
mannyman2
Jan 29, 2008 09:08 PM
RTW DC2R
Feb 20, 2006 11:20 AM
_Endless_
Mar 11, 2004 06:37 AM
