JRSC boost upgrade question.
Old Jan 3, 2005 | 03:31 PM
Tad's Avatar
Tad
Default JRSC boost upgrade question.
I want to acheive 9psi on my sohc jrsc kit.
currently i'm running the stock 6psi, but will be upping it soon,
i'm not quite sure how to go about it though.
Basically the only two options for the sohc kits are crank pulley or SC pulley.
now the smallest SC pulley I can run, will net me 8psi..
but I don't like the idea of a bigger crank... cuz it'll be heavier..
so what's my best course of action?
Is there any performance difference between upping the crank size or lowering the SC pulley size??
thanks!
Old Jan 3, 2005 | 05:19 PM
integ6657's Avatar
Default Re: JRSC boost upgrade question. (Tad)
The easiest thing to do is to upgrade to a crv pulley B20 {crank} however...it will overdrive your ac, alternator ect. a little because the pulley is bigger. Your best bet would to be contactin Jim at mortorvations motorsports. he sells a pulley for the alternator that will up your boost to about 9 PSI and bolts right on. This keeps you from having to pull the blower loose to remove the pulley or removing the crank pulley. It also helps keep the longevity of your alt. ect. I'm not sure what his # is....but if you search...you can find it. Good luck! Ps--- the b20 pulley will give you about 10 -11 PSI
Old Jan 3, 2005 | 05:41 PM
drive4show's Avatar
Check out Unorthodox Racing's Ultra SSc crank pulley. Overdrives the alternator only, giving the extra boost you're seeking. It's very light, way lighter than the stock crank pulley.
Old Jan 3, 2005 | 06:34 PM
Tad's Avatar
Tad
Default Re: JRSC boost upgrade question. (drive4show)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drive4show &raquo;</TD></TR><TR><TD CLASS="quote">Check out Unorthodox Racing's Ultra SSc crank pulley. Overdrives the alternator only, giving the extra boost you're seeking. It's very light, way lighter than the stock crank pulley.</TD></TR></TABLE>
ah I see, ok i'll look into that.
hmm, I'm worried about the alternator thing though,
i've had charging problems in the past and don't look forward to more.
I can't use any stepper pulley, like the jim motorvations thing,
thats for bseries only. the sohc runs one belt that goes around all 3 pullies(crank alt sc)
i dont have any ac or ps though so no worries there.
Old Jan 9, 2005 | 11:10 AM
joetrisman's Avatar
Tad,
from what I understand, the d15b crank pulley is larger, and thus will spin the alt faster and the s/c faster. Although, I don't know how much psi that will net
Old Jan 9, 2005 | 11:26 AM
Tad's Avatar
Tad
Default Re: JRSC boost upgrade question. (joetrisman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joetrisman &raquo;</TD></TR><TR><TD CLASS="quote">Tad,
from what I understand, the d15b crank pulley is larger, and thus will spin the alt faster and the s/c faster. Although, I don't know how much psi that will net</TD></TR></TABLE>
whered you hear that??
Old Jan 9, 2005 | 11:47 AM
rothjpkb's Avatar
ok i know jacksonracing has more pulleys for your apt. if you
call or email them thay can hook you up for i think it's around
$30 however some times thay don't have a specific one but thay
a company thay recommend
Old Jan 11, 2005 | 08:14 AM
joetrisman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">whered you hear that??</TD></TR></TABLE>
Somewhere in the archieves....
Old Jan 11, 2005 | 10:08 AM
gitwidit's Avatar
On my old Z6 I ran the CRV pulley and the 8psi JR pulley. Ended up with 10psi, never had any problems with the alternator/charging system.
Old Jan 11, 2005 | 11:56 AM
Tad's Avatar
Tad
Default Re: JRSC boost upgrade question. (GITWIDIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT &raquo;</TD></TR><TR><TD CLASS="quote">On my old Z6 I ran the CRV pulley and the 8psi JR pulley. Ended up with 10psi, never had any problems with the alternator/charging system.</TD></TR></TABLE>
cool, no probs with the charging system huh, thats good to know.
any clue how much the crv pulley makes with the stock SC pulley?
i'm thinking I might just find the right diameter crank, and
get a lightweight one from unorthodox or something, like made for a crv.
Old Jan 15, 2005 | 08:17 PM
HYREV2NR's Avatar
IF u have the D series, doesen't it only have 1 belt to drive the SC? & if your worried about over speeding the alternator, change the crank pulley & get the Unorthodox underdrive pulley for the alternator & that will cure the problem.
pokmijn
Jun 23, 2009 04:07 PM
gosu08
Jun 17, 2009 01:16 AM
Blk00EJ8
Jul 28, 2004 07:32 PM
suprchrg95
May 17, 2004 01:10 PM
Replica
Dec 3, 2002 04:42 AM
